03-29-2013, 11:56 PM | #1 |
69 C10 Drum/Drum problem please help!
My 69 C10 has manual brakes with drum/drum. I replaced all the brakes 1 1/2 years ago and have not had any problems till today.
I went for a drive and I started smelling a burning smell and was taking alot of extra effort to brake. I only drove 10 miles and when I stopped to check what the smell was I knew it was the brakes. The front drums were smoking hot and the left rear drum was hot as well. The right rear drum was cool. The other 3 were so hot that when i splashed water on them they were sizzling and steaming. I have not had any problems till now, it never pulled one way or the other. What could cause 3 of 4 drums to be so hot? I was going to adjust my shoes in the next week but that was before this happened. I have no clue what the problem could be. When I redid the brakes it was new rubber hoses, master cylinder, shoes and wheel cylinders. Still the same hard lines. Thank you in advance for any help you may provide.
1952 Chevy 3100 1969 Chevy C10 2006 Chevy 1500 |
03-30-2013, 09:48 AM | #2 |
Re: 69 C10 Drum/Drum problem please help!
You probably need to adjust the mastter cyl. rod to have a small amount play before it contacts the master cyl. If that is not it the master cyl. is sticking.
03-31-2013, 06:41 AM | #3 |
1969 Custom 30 wrecker
Ok, this is a real wild odd shot possibility but it happended to me so I'll mention it.
Make sure the holes inside the master cylinder are open. I had a small piece of the foil seal from the brake fluid bottle get in there one time when I added brake fluid and it got sucked into one of the holes making the brakes not release all the way. DROVE me crazy trying to find the problem...
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
