03-30-2013, 01:08 AM | #1 |
Vintage air cab kit, what compressor and condenser?
Normally I would post this in the 47-59 board but I believe you guys deal with more A/C kits. My setup is a 57 Chevy 3100 with a small block. I plan to purchase a Vintage Air Gen II cab kit.
My question is what type of compressor (v-belt setup on passenger side) and condenser will work the best but not break the bank. Generally I am a cheap bastard that won't buy anything new but this is probably not the time for that. Thanks in advance for any help given. |
03-30-2013, 06:51 AM | #2 |
Old member
Re: Vintage air cab kit, what compressor and condenser?
It depends on which system you go with. R-12 are 134 a.
I went with 134 a and bought the components to operate it at the peak performance and did away with the POA valve. I would recommend the smaller sanderson compressor like mine.
03-30-2013, 11:15 AM | #3 |
Thanks Andy, I also plan to run it on 134a.
03-30-2013, 12:36 PM | #4 |
Old member
Biggest thing I have found is 134-a requires less freon than R-12 to get it to perform well. So make sure whoever does it knows what to do with it.
03-30-2013, 07:05 PM | #5 |
So instead of buying the sure fit kit for the 55-59 you're just looking to buy the in cab kit and piece the rest together? You might spend more but you may save A TON of hassle buy getting the complete kit. With the sure fit kit, tell them what motor you have, long or short water pump, and what side of the motor you want it on and you'll get the right engine bracket and because it's a sure fit kit it will properly fit a 55-59.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-30-2013, 07:48 PM | #6 | |
03-31-2013, 07:58 PM | #7 |
I have a brand new vintage air compressor that I purchased last august, still in the box I'll take an offer on. I ended up purchasing a new zz4 crate motor with a front serpentine system, which has a new compressor on it, so don't need the vintage air?
Shoot me a pm
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
04-04-2013, 03:31 PM | #8 |
What does this mean that the compressor does not have service ports?
http://phoenix.craigslist.org/wvl/pts/3661859418.html |
04-05-2013, 12:05 AM | #9 |
never mind the above post, I figured it out. Some new research says that I might be able to put this kit together myself and save ~$200.
I can get the cab kit on Ebay for $475 shipped. If I go through Vintage air the rest of the kit looks like this without shipping. $295 Sanden compresser and bracket $140 Parallel flow condenser $110 Hose kit with dryer $35 Binary switch comes out to $578 plus the $475 ebay kit for a total of $1053. If I go with piece parting it together I get $45 Allen Grove compressor bracket (scored on craigslist) $140 Sanden compressor $100 parallel flow condenser $90 Barrier, beadlock hose kit, fittings, dryer, and binary switch comes out to $360 plus the $475 kit above for a total of $835 Either kit will have hose crimping prices, and I have a friend who can evacuate it and charge it. One problem with buying it myself is I will have to size the condenser and compressor a bit on my own. Any more thoughts? |
04-05-2013, 06:43 AM | #10 |
Old member
Look at the kit for your model and call about it ask what size it is. Then go from there. The compressor shouldn't matter what size the system is.
04-05-2013, 12:25 PM | #11 | |
Tell us about your evaporator and expansion valve..
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD. 1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc |
04-05-2013, 12:27 PM | #12 | |
Looking on ebay, but only found a mini kit for a camaro, any help? Ill follow along to see how you make out, i only want to have heat and defrost in my cab.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-05-2013, 03:33 PM | #13 |
Old member
I got all of it out of a late 80's chevy truck out of the junk yard. I ran it for a year are so with R-12 but the A-6 compressor kept chewing up clutches so I decided to redo it. I bought new stuff for the 134-A freon. Everything is factory looking except the compressor. The AC works great with the cowl vent mod I did. I used some of the spray insulation to mask off the evaperator and the POA valve was replaced with the expansion valve in the bottom AC line.
04-05-2013, 04:44 PM | #14 |
I put the VA inside kit in my 70. I used a factory comp. with short water pump brackets, & pulleys from a salvage. I took the dementions to the junk yard & found a condenser to fit. It wound up being from a Saturn. Making up the hoses was the hardest part.
