03-30-2013, 02:18 PM | #1 |
windshiels washer
'69 c10, checked for washer not working, removed whiper motor with pump and checked pump and it works ok on the bench, coil pulls in the stop and workd untill it gets to a high spot on the plastic wheel and it holds the pump arm from moving in, cant get it to release when the coil is pulled in, need a new assy or can this be a repair?
03-30-2013, 03:55 PM | #2 |
Re: windshiels washer
never had any luck with those, i always put an electric pump in line
03-30-2013, 04:11 PM | #3 |
The stock pumps on these trucks are garbage. Just get a bottle off a newer S10. You'll get a bigger reservoir, and the motor is built in to the bottle. Very easy fix
Posted via Mobile Device |
03-30-2013, 04:45 PM | #4 |
I am currently having the same problem. So with the s10 pump and reservoir, is that wired to a new switch/button or can you wire it to the original wiper button?
03-30-2013, 06:19 PM | #5 | |
If you search my old posts, there are instructions Posted via Mobile Device |
03-31-2013, 07:45 AM | #6 | |
Thanks Posted via Mobile Device
1970 C10 Short Stepper with 71/72 front clip. |
03-31-2013, 10:28 AM | #7 | |
If you still need another pic, let me know, but Lee's pic should help Posted via Mobile Device |
03-31-2013, 10:50 AM | #8 |
I installed an ac delco electric pump under dash and wired it to wiper switch works just like factory just much better.
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
03-30-2013, 06:27 PM | #9 |
Mr. B is right, very easy mod and it works far better than stock. About $6 bucks at your local pick a part.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
04-06-2013, 09:43 PM | #10 |
Got one like this for mine today. Sucker pumps like a beast now...
05 QSM GTO - M6, Corsa, King Springs 70 SWB CST - 350/Auto, Foose 18/17 I upset whiners too.... |
03-30-2013, 06:29 PM | #11 |
Good idea, been having trouble with mine, already ran all new hoses.
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
03-31-2013, 06:36 AM | #12 |
1969 Custom 30 wrecker
I wouldn't say these pumps are garbage. All mine work just fine. (and I have 9!) The only problem I ever had was if a vehicle sat a long time or was run out of fluid, you have to reprime it.
This style pump was used on GM cars & trucks for a long time. I'd rather use original parts instead of tacking on new parts to my old trucks. No S10's for me.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-01-2013, 01:46 PM | #13 | |
04-02-2013, 06:54 AM | #14 |
If the pump makes the clicking sound but no fluid, you just reprime by taking the cap off the washer tank, flip it over and attach a funnel to the hose. Fill with water and then work the pump. Gravity will help the water to make it's way to the pump. Once it starts squirting, simply remove funnel and replace the cap. If there are no other problems it should be all fixed.
04-02-2013, 10:10 AM | #15 | |
03-31-2013, 11:10 AM | #16 |
Any S10 or full size are about the same size, pump in front or back, your choose.
04-07-2013, 12:44 PM | #17 |
Mine has a different problem. It pumps great but will not shut off until I turn the wipers off then I have the last squirt running down the windshield. If I turn the wiper back on it starts pumping again. Bad switch?
04-07-2013, 02:40 PM | #18 |
Simple? What's simple?
More likely the pump is stuck - there's a little actuator inside there that pulls the linkage into the "pump" position when you push the switch, but it's driven from the wiper motor so if it doesn't return, it will pump anytime the wipers are on
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
04-07-2013, 06:10 PM | #19 |
I used one of my little girls snot sucker bulbs to prime mine so fe she is old enough to blow her own nose!
04-08-2013, 12:20 AM | #20 |
Moderator
I agree the stock units are junk after 40 years. I never had any luck priming one. If you want to retain the factory look, simply pull the washer pump from the S-10 straight up, and it pops right out. Splice it into your feed line and mount it on the fender inconspicuously. You keep the factory reservoir and upgrade performance at the same time. Worked perfect on my other truck, and I plan to do the same to my current truck when I get it back.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 04-08-2013 at 12:26 AM. |
05-26-2013, 03:57 PM | #21 |
which wires are you all using to power the new style pump?
1968 chevy c10 lwb, 250 inline6, 4 speed, |
05-26-2013, 04:55 PM | #22 |
RAT1968 '68 Cab/'71 Parts
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=433033 and http://67-72chevytrucks.com/vboard/s...27#post4958227
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
10-18-2013, 11:06 PM | #23 |
If you install the s10 pump or pump resivoir set up do you route it through the existing pump? Basically the existing non working pump becomes a manifold?
