Old 03-30-2013, 02:43 PM   #1
Godfather240sx
Trying to figure out what transfer case I have.
I have a 76 K5 blazer that I'm getting ready to fix up and get back on the road. It has a 350 and an auto trans. I have read some of the other treads to see if it will help me figure out my transfer case but they have not helped. The thing that's different from all the transfer cases I have heard discribed in the other threads is the shift patern. Starting the whole way front and working back it has L LOC - L - N - H - H LOC. I'm guessing that the L and H LOC would by low and high four wheel drive and the L and H would be low and high two wheel drive, is that correct? The Trans is shot and I'm checking prices to rebuild or replace it. If I replace it I want to find a Trans that will work with this transfer case.
Thanks in advance for any help you can give.
Godfather240sx is offline   Reply With Quote
Old 03-30-2013, 04:08 PM   #2
72shorbox
Re: Trying to figure out what transfer case I have.
Looks like you have the NP 203 transfer case.
72shorbox is offline   Reply With Quote
Old 03-30-2013, 04:20 PM   #3
Godfather240sx
Ok. Thanks.
Like I said the L and L loc is what was throwing me off.
Old 03-30-2013, 04:54 PM   #4
Godfather240sx
So would L be two wheel low and L LOC be four wheel low? I was reading that some of the NP 203's where full time four wheel drive and some where converted to part time four wheel drive? I know the blazer has locking hubs and I always used the L and H with the hubs unlocked and the L LOC and H LOC with the hubs locked in.
Old 04-03-2013, 10:59 AM   #5
72shorbox
you would be correct on "L" for 2wd low range and "L LOC" for 4wd low range.
Old 04-03-2013, 11:17 AM   #6
Godfather240sx
Thanks for the help.
By your name I take it you own one of my favorite model trucks. The first thing I bought when I was 16 was a 72 c10 (long bed) and I wish I still had it. I have been looking for another one for years but you can't find them in decent shape for a decent price anymore. I just got a lead on a 72 k5 two wheel drive that I want to check out.
Old 04-07-2013, 11:21 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
thats how my 78 203 is ,don't know whats in it but
I read a mile marker kit will do it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-27-2013, 07:53 AM   #8
RoughKuntry
RoughKuntry's Avatar
Motornut, Thanks for the information, I have the same Transfer case In my 79 Jimmy, however I can not tell the transmission, besides it being a 4 Speed. The transfer case, states Model 203, Ratio 201, Serial 11 2 79. What is odd is I don't have a transmission pan, only a bolt at the bottom where I can drain the Transmission Fluid. Have any Suggestions?
_________________________
1979 GMC High Sierra Jimmy 4x4
1973 GMC 350-4 V8 2500 4x4
1984 Chevy Dully Crew Cab 454 V8 4x2
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
Old 05-28-2013, 10:03 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
4 speed with overdrive uses ATF
others use 80W oil
should have an upper bolt for check/fill
lower to drain it
John
Old 05-28-2013, 03:01 PM   #10
RoughKuntry
others use 80W oil
lower to drain it
I don't have overdrive. only L, 1, 2, 3, R on the Shifter, with a 203 Transfer case
RoughKuntry
Old 05-28-2013, 04:32 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
then it should be 80 oil
but when you drop it you will tell too
203 is 10/30 or 10/40 oil
John
Old 05-29-2013, 12:54 AM   #12
83GMCK2500
Your manual trans is an SM-465, look: HERE
To the OP and others, NP203 clarification: HERE (scroll past diagram)
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-29-2013, 06:51 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
some good info there
John
Old 06-09-2013, 03:29 AM   #14
jon75
jon75's Avatar
Your transfer case is a "full time" case, according to the GM owner's manual. Part-time cases only have L-N-2H-4H for modes.
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB
2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes
ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a
jon75 is offline   Reply With Quote
Old 06-09-2013, 05:52 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
yes but with a "mile marker" brand kit it makes it part time too
John
Old 06-10-2013, 09:58 AM   #16
RoughKuntry
Its really hard to say, because I haven't gotten that far yet about taking the transmission and transfer-case out. I still am working on getting a Steering Column from Mike.
RoughKuntry
