03-30-2013, 04:27 PM | #1 |
switching 6 lug drum to 4 3/4 5 lug disc questiond
I'm working on a 1969 Swb and I'm wanting to switch the 6 lug drum brakes on the front to 4 3/4 5 lug disc. I would prefer to go to the junkyard and pull parts from donor vehicles and rebuild the front end myself. I'm doing a 4 1/2 inch drop using 2.5 in drop spindles and a 2 inch drop coil in the front and 6 inch drop in the back. Has anyone done this swap before. I'm also wanting to keep my drum brake A arms because they have already been painted by the previous owner of the short bed frame I bought. Any help is greatly appreciated.
Thanks, Scott
Scott |
03-30-2013, 06:04 PM | #2 |
67-72 parts collector,…
Re: switching 6 lug drum to 4 3/4 5 lug disc questiond
Have you bought drop spindles yet?
03-30-2013, 06:06 PM | #3 |
03-30-2013, 06:07 PM | #4 |
I haven't bought the spindles yet Keith
Scott |
03-30-2013, 06:08 PM | #5 |
I tried to decipher that thread it confused the heck out of me
Scott |
03-30-2013, 06:15 PM | #6 |
Parts needed:
81-87 Light Duty drop spindles. (for 1" rotors) 81-87 Light Duty calipers 91-92 Camaro 1LE (special option) rotors (5x4.75 bolt circle) You will have to use 73-87 ball joints, and outer tie rods. I would get ALL the steering off of a 73-87 truck.
03-30-2013, 06:16 PM | #7 |
thank you that's much easier
Scott |
03-30-2013, 06:17 PM | #8 |
The ball joints and tie rods were confusing me and which steering linkage to use
Scott |
03-30-2013, 06:19 PM | #9 |
Will I need a new steering gear box too? or I can I use my 1969 power steering box I have already.
Scott |
03-30-2013, 06:20 PM | #10 |
Camaro 1LE rotor specs:
03-30-2013, 06:20 PM | #11 |
What are you going to do with the rearend?
03-30-2013, 06:26 PM | #12 |
Changing out the rearend to 5 lug but not sure which rearend I have yet? I paid for my frame and its still sitting where I bought it from, I ran out of room here till I get my shortbed I parted out completely and moved out of the driveway. I want to put 5 lug disc on the back also.
Scott |
03-30-2013, 06:51 PM | #13 |
Truthfully the McGaughy's or CPP big brake kit is the easiest way to get a 5x4.75 pattern.
(more money) You should be able to use your '69 steering box. Seems like alot of work to get a specific 5x4.75 bolt pattern wheel. (plus the center hub of your 6-lug rear axle is HUGE compared to a 5x5 truck rearend or a car pattern 5x4.75 rearend) Sometimes people end up spending more money on the suspension, to save a few bucks on wheels. Personally,... I would just add 63-70 drop spindles to your truck and use stock 71-87 HD 5x5 rotors and calipers. You will need conversion brake hoses. ECE sells those. Everyone has there reason for the wheels they choose. I just like to know all the options. You won't go to a junkyard and find bolt on 5x4.75 conversion parts.
03-30-2013, 06:59 PM | #14 |
I agree with you about it seems like a lot of work after I got to thinking about it after just reading everything you provided. Maybe I'll just stick with 81-87 suspension and do it that way. Thanks for the help Keith, you're always a great help.
Scott |
