03-30-2013, 04:56 PM | #1 |
350 vibration
I have a 84 Chevy 4x4 with a 350 auto. At idle it vibrates and when revved up you can feel it vibrate. I thought it was missing but you can put it in gear and give it gas and hold the brake and it does not miss. I replaced the plug wires and the plugs looked good. Could it be the harmonic balancer? I need it smooth because I am trying to sell the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
03-31-2013, 09:11 AM | #2 |
Re: 350 vibration
Could be the H.B., but I'd check 1 more thing before I replaced it... Run a compression test across all the cylinders and make sure they are even. It could be all 8 are firing, but 1 cylinder is way weaker than the others. For example all are 120 and one is 80, or some stuff like that. A burnt valve can act like this.
03-31-2013, 08:44 PM | #3 |
78K & 79C Jimmys
Re: 350 vibration
check for bent/cracked/broken fan blades
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-31-2013, 08:53 PM | #4 |
Re: 350 vibration
Thanks for the replies Compression was good. I slowed the timing down a little and it seemed to help at idle. The engine runs very well so it shouldn't be much.
03-31-2013, 09:12 PM | #5 |
Re: 350 vibration
Just tell 'em it has a mean cam in it
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
