03-30-2013, 06:20 PM | #1 |
Welder setting?
Im trying to find the perfect setting for my welder to use on my 71's sheet metal Dose anyone have them ?
03-30-2013, 07:12 PM | #2 |
what kind of welder?
03-30-2013, 08:01 PM | #3 |
Re: Welder setting?
miller 210 /miller 211
03-30-2013, 10:28 PM | #4 |
Re: Welder setting?
75/25 argon co2 mix? what gas are you running?
Posted via Mobile Device Last edited by BOHICA-Chevy68; 03-30-2013 at 10:29 PM. Reason: Misspelled word |
03-30-2013, 10:36 PM | #5 |
Re: Welder setting?
If your using 75/25 and .030 wire start at 50-60 amps and 120-130 ipm for wire speed.
Posted via Mobile Device |
03-30-2013, 10:43 PM | #6 |
Re: Welder setting?
ok thank you!
03-31-2013, 05:25 AM | #7 |
Re: Welder setting?
read the instruction book
inside of cabinet miller has a chart for usage, a good start for u to start dialing in the settings practice practice practice
03-31-2013, 09:00 AM | #8 |
I am a Referee of life.
Re: Welder setting?
Also most Millers come with a guage to check the metal guage.Then you set it auto to that guage.You will probably have to tweak a bit to get there.It's usually a good idea to have some scrap to test your welds on before doing the actual work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-31-2013, 10:44 AM | #9 |
Re: Welder setting?
Use .023 wire.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
03-31-2013, 12:59 PM | #10 | |
Re: Welder setting?
Agreed. For light sheet metal, it is better. It takes less power (heat) to make your welds, which reduces burn-through and warping.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
03-31-2013, 01:11 PM | #11 |
Re: Welder setting?
Agreed on the wire (.023). I am a novice at welding and did cab corners, inner and outer rockers, kick panels and partial floor pan. I used .023 wire and had the welder on the lowest heat setting, still had some spots I burned through.
///Relaxed Atmosphere |
03-31-2013, 01:16 PM | #12 | |||
"I ain't nobody, dork."
Re: Welder setting?
Plus after a few spot welds you might have to tweak the settings to slow or speed up the wire or make the heat hotter or colder. So the setting in the cabinet are just a baseline to get you started. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-31-2013, 11:39 PM | #13 |
Re: Welder setting?
I use pieces of copper clamped to the back. Various sizes 1/4" thick. Also not mentioned is don't run a bead, use lots of "tacks". If you pay close attention there my be some warping. Sometimes I use a hammer and dolly to relieve stress. Oh, the copper isn't a must, just something that helps me not a must. Practice - dial in - patience good clamps/vise grips help.
Posted via Mental Telepathy
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" Last edited by Spartan; 03-31-2013 at 11:42 PM. Reason: More info |
