Old 03-30-2013, 08:15 PM   #1
OregonNed
OregonNed's Avatar
Engine block numbers
I am certain the restored '68 I bought has the original 327 in it that was rebuilt in '07 - however, there are no numbers etched on the pad in front of the right cylinder head. Is that normal at all?
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-30-2013, 08:37 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Engine block numbers
If the machine shop machined the deck surface, that would wipe the stamped code off. It will be on the passenger side front.
TBONE1964 is offline   Reply With Quote
Old 03-30-2013, 09:20 PM   #3
Fldawg
Fldawg's Avatar
check driver side just below the head at the firewall block numbers will be there
Fldawg is offline   Reply With Quote
Old 03-30-2013, 09:32 PM   #4
OregonNed
OregonNed's Avatar
That is probably it - passenger side front. Ill check in back by the firewall for the casting numbers. Thank you
