03-30-2013, 09:41 PM | #1 |
D5 Cat Dozer
So today I got a phone call, and long story short, needed to do some metalshaping for a Caterpillar D5 dozer. No, really! The last time this same mishap occurred was over ten years ago in my back yard. It seems dirt/mud gets packed between the stump pan and the oil pan, until a hole rusts through the oil pan. Last time Paul bought a new oil pan, but it sounded like he needed to use the dozer this week, so he brought it over for repair..
The heat marking is where he was attempting to braze it closed, with little success. Calipers showed the pan to be 14 ga, and I just happened to have some in stock. I've used the bead roller before to form a radius, but never on metal this thick before. This will be a good test of the fancy 75A durometer skateboard wheel to see how well it works. Took a few passes, but worked real nice. Now for a relief cut and a weld... Rust hole removed, patch trimmed and fitted, then welded in place.. .....and Paul cleans it up for paint.. You never know what you see over here in the shop...
Robert |
03-30-2013, 11:06 PM | #2 |
Re: D5 Cat Dozer
Looks great! Love to see more pics or info on how you cut the rounded corners.
"I feel the need for speed!"... as soon as I am done with my nap. |
03-30-2013, 11:39 PM | #3 |
Re: D5 Cat Dozer
The rust was rough cut out with a 3" x .035 cutoff wheel, then the blue die grinder shown there has a 1-1/2 diameter drum sander on it, used it to dress the radius edges in the cutout on the pan, the patch was rough cut on the band saw and dressed with a roloc disc...
Robert |
03-31-2013, 07:16 PM | #4 |
I am a Referee of life.
Re: D5 Cat Dozer
Looks like a good job.It would be nice if he had time to get iit powdercoated so it wouldn't happen again.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-31-2013, 09:32 PM | #5 |
Tot Roddin'
Re: D5 Cat Dozer
Amazing skills!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-02-2013, 11:26 AM | #6 | |
The One And Only !!!
Re: D5 Cat Dozer
Nice job ! A good wash out with a pressure washer once in a while would prevent it, We do it to our skid loaders for that reason......
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
04-03-2013, 06:27 PM | #7 |
MOVE OVER
Re: D5 Cat Dozer
agreed, sometimes these posts just make me realize how insignificant I really am..
No matter where you are..... There you are... Buckaroo Banzi |
