Old 03-30-2013, 10:17 PM   #1
71badblue
71badblue's Avatar
aftlertumbermarket lock and
so i bought a new lock and tumbler for my 7tumbler1 at oreillys. so i take and off the bezel that or retainer nut whatever in its called. put new tumbler in go to put ignition back in the dash and the damn bezel nut wont fit over new tumbler. is this common? should i take it back or just go to oreillys and see if they can order me the same brand bezel nut?
71badblue is offline   Reply With Quote
Old 03-30-2013, 11:29 PM   #2
ole dollor
ole dollor's Avatar
Re: aftlertumbermarket lock and
can you put it back together and then put the new lock in...try and see if it will work like that.
ole dollor is offline   Reply With Quote
Old 03-31-2013, 08:34 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: aftlertumbermarket lock and
I have always installed the cylinder first then put the tubbler in after it's in the dash with the key.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
