Old 06-19-2003, 12:28 PM   #1
gldevall
gldevall's Avatar
Gauge pics
Does anyone have any close up shots of Autometer gauges mounted from the outside of the bezel? I guess you would probably call it top mounted. Not like Swervin's, I would call his bottom mounted. Even though his gauges are bad a$$, I don't think I enough patients to do mine like that.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 06-19-2003, 12:44 PM   #2
bigblock73
yeller
bigblock73's Avatar
Eddie has his done that way...maybe his slacker butt will chime in!
...Jeff
bigblock73 is offline   Reply With Quote
Old 06-19-2003, 01:48 PM   #3
BigRed
There's a couple on here, but not sure if they're are close enough for you.
http://www.shelbournes.net/trucksite...iors/index.htm
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-19-2003, 02:55 PM   #4
gldevall
gldevall's Avatar
Thanks Scott, but I really need something a little closer.
Old 06-19-2003, 04:33 PM   #5
PHOENIX
Scott has pictures of mine on that link and if you click them they will get a little larger. Let me know what you are looking for as far as details or something and I can post some pictures or email them to you depending on the picture size.
<-------- Been slackin' online, but getting a lot of work done
<--- I like!
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-20-2003, 09:12 AM   #6
gldevall
gldevall's Avatar
Yeah Eddie, I want to install mine the way your's are. I already have the fuel gauge in, but wanted to see how it compares with some others. IF you could email a couple of pics to devall@cox.net I would really appreciate it.
Old 06-20-2003, 11:03 AM   #7
PHOENIX
You've Got Mail
Old 06-21-2003, 06:29 AM   #8
TIMSPEED
TIMSPEED's Avatar
Eddie,
Did you use the stock bezel, or did you just put in a piece of plastic and cut it?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-21-2003, 01:43 PM   #9
PHOENIX
stock bezel
Old 06-22-2003, 08:54 PM   #10
81chevystep
ShadeTree Kustomz
81chevystep's Avatar
is this what you are talking about
81chevystep is offline   Reply With Quote
Old 06-22-2003, 09:26 PM   #11
gldevall
gldevall's Avatar
Yeah that's it. Where did you get the billet from? Thanks.
Old 06-22-2003, 11:33 PM   #12
81chevystep
ShadeTree Kustomz
i got it from trenz but i orderd it through a local custom shope it cost about $100 but you have to make the holes bigger to fit the guages in them.
Old 06-23-2003, 10:36 AM   #13
PHOENIX
They have polished and brushed finish.
Make sure you get the one you want.
Everyone sells the brushed, but I guess the polished are harder to find. Contact Swervin for info on the polished one.
Old 07-03-2003, 11:33 PM   #14
82 'ject
Alleged Member
Phoenix, it appears that your gauges point directly forward as opposed to upward towards the driver. If this is accurate does it affect how well you can see the gauges?
82 'ject is offline   Reply With Quote
Old 07-03-2003, 11:35 PM   #15
82 'ject
Alleged Member
Sorry my previous post was for 82 chevystep
Old 07-04-2003, 12:51 PM   #16
81chevystep
ShadeTree Kustomz
they do point straight forward and i can see all of the guages fine. hope that helps.
Old 07-04-2003, 01:11 PM   #17
Jonboy
Slots go on anything!
are those 2 5/8 gauges or 2 1/16 for the small? I am guessing the larger ones are 5"?
1974 Jimmy- 5.3/4L80e/NP241
Old 07-04-2003, 01:16 PM   #18
bigblock73
yeller
bigblock73's Avatar
they are 2 5/8" I believe.
Old 07-05-2003, 11:27 AM   #19
bigd65
bigd65's Avatar
81, that looks awwsome
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 07-05-2003, 08:30 PM   #20
kevhill85
91 SWB 383
kevhill85's Avatar
here the pic of mine . it u go to the web site there is a few more
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 07-05-2003, 08:35 PM   #21
kevhill85
91 SWB 383
kevhill85's Avatar
this will tell what gauges i use and part numbers
http://www.mychevytruck.com/showowne...&n=84329&pos=3
