Old 03-31-2013, 01:31 AM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Electric fan experts help. 91 K5 blazer
Ok so I need something under the hood that I can tie into that only hot when the key is on. It is for my 210 fan relay if that matters. Also it's got a green wire that says its for the ac clutch. Where do I tie that into.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-31-2013, 03:11 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Electric fan experts help. 91 K5 blazer
First of all, the green wire goes to the power wire for the A/C compressor. It will splice in and when you turn on your compressor the power will feed to the fan relay and start your electric fan. As for turning your fans off when the key is off, all you have to do is find a circuit that is controlled through the fuse panel that is on with the key and off when it is off. Many fuse blocks have ignition terminals in them that you can tap off of. If not, then a circuit for your radio or such can be used as a source. This circuit does not have to be wired to the fan or fans, they should get power directly from your battery, this power should go to a realy that turns the fans on, so there is no overload on the ignition circuit or fuse block. Remember before passing through the firewall to the engine compartment, put a fuse in the circuit to protect the truck, if the wire were to get a bare spot in it.
Frank
piecesparts is offline   Reply With Quote
Old 03-31-2013, 04:27 AM   #3
TheApocalyptican
TheApocalyptican's Avatar
As long as your are using a relay...use the ign wire for the wiper. That's how I did mine. That way you only have to run wires in the engine compartment.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 04-01-2013, 05:29 PM   #4
jimbonice
jimbonice's Avatar
For my fan on my trans cooler, I just wired my relay up to a switch on the dash from the second battery. I usually leave it on. It shuts itself off when it's cool enough.
jimbonice is offline   Reply With Quote
