Finally Got To Run The Bucket At The Track With The Nitrous
got to run the bucket last tuesday night at our grudge night here in indy. with the powershot nitrous i improved from a 13.86 at 94 mph to a 12.81 at 104 mph. got my rpm activated window switch set up for 3000 and 6000 for protection. my best 60 ft time was a 2.02 and my best reaction time was .002. surprised alot of spectators who did not think the truck would go faster than 14's. you guys should have seen the looks on their faces as i drove back from picking up my time slips. i wish i had a camera.
MITCH1914 |
what kind of tires and gears do you have?
The Blazer King
Tire size?
Gears? Tranny? Motor Mods?
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
Post Whore
![]() Join Date: Feb 2000
Good to love that! Maybe Mastercard ought to use you for one of their Priceless ads.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
MITCH1914, sounds like it's running good. What was your 1/8 mile time and mph? What size nitrous shot are you running?
i am running the BFG drag radials 325-50-15 on 8 1/2 corvete ralleys. i ran the tire pressure at 16
engine mods 400 sb 30 over, 9.75 to 1 hyperutectic pistons, 350 heads modified to go on a 400. the heads have also been pocket ported, 3 angle valve job, they still have the stock valves. i have a comp cams 270 magnum with 1.6 roller tip rockers, flowtech headers, edelbrock perfromer intake, a used 600 vac secondary holley that the old man modified and jetted up (i dont know what he did to it but it works very good). msd6a ignition. the block was decked and the heads milled a little to make them level. tranny is a 400 turbo with 2200 stall the rearend is posi via the the powertrax system, i have 373 gears STROKER 383 1/8 times werer in the 7.80 range ( i dont have the time slip in front of me now) it felt like the truck ran out top very strong. how does yours run from 2nd gear on out on the bottle and what gears do you run. oh yeah i am running the 125 powershot MITCH1914 |
MITCH1914, I have 3.73 gear. It pulls hard in every gear. I run 28x9" Hoosier Slicks, My best 60ft was 1.77. Does your truck spin much off the line?
Have A Nice Day!
Sounds like you had fun. Congrats on the E.T. - 12.81 is a nice number
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() |
388Stroker Doesn't spin hardly at all....I soft pedal it the first 10 feet and then mat it after that....I wait for the rpm window switch to take over. The reason why I ask if it pulls hard up top is coz I noticed that the truck running hard and fast in second and drive...Maybe I was just so excited I did not notice the bottom end power. But it is there coz the truck is coming out very quick. Mitch1914
If it doesn't spin much you could try a adjustable MSD rpm chip to turn the nitrous on sooner. That might help your 60ft times. I have mine coming on at 2500rpm.
383 stroker that sounds like a good idea. i'll have to get hold to a 2500 module, i bought the 3000 and up pack (even numbers)
