Old 03-31-2013, 08:12 AM   #1
ecgate
ecgate's Avatar
Steering is really stiff?
I just got done putting together my front end on my 67. I have all new everything on it. And I can barely turn the spindles with my hands. Could it be really stiff from over tightening the nuts on the spindles, tie rods, pitman arm, and idle arm. I didn't know how tight to torque the nuts so I just snugged them up. It went together really smooth so I don't think anything is binding up. Any expertise would help. For your info I have a bare frame with just the front steering and suspension on it.
ecgate is offline   Reply With Quote
Old 03-31-2013, 09:08 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Steering is really stiff?
Have you greased the ball joints and tie rods yet? That may help a little. Over tightening the nuts will not cause your problem.
Make sure you have nothing binding. If greasing does not help, remove the tie rods from the spindles and see if it still feels hard to turn.
Also remember, if you are trying to turn the steering by the spindle, there is not a lot of leverage there and it may feel harder to turn than it is.
TBONE1964 is offline   Reply With Quote
Old 03-31-2013, 10:12 AM   #3
Sammy
Agreed.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-31-2013, 10:12 AM   #4
ecgate
ecgate's Avatar
I did grease everything but that didn't seem to help. I think Ill try to take the tie rod ends off and see if that helps.
Old 03-31-2013, 02:42 PM   #5
FirstOwner69
FirstOwner69's Avatar
If everything is brand new, it should be fairly tight. I assume you replaced things because they were worn/old... and probably loose.
I suggest that you get it on the road and see what happens before you lose too much sleep over it. As stated above, just be sure it's greased first.
Also, you don't have much leverage just grabbing the spindles to turn.
FirstOwner69 is offline   Reply With Quote
Old 03-31-2013, 03:42 PM   #6
ecgate
ecgate's Avatar
Dont kid yourself i would love to be on the road but the rearend and frontend are the only parts on the frame. Im in the process of building a truck from the ground up.
Old 03-31-2013, 04:18 PM   #7
FirstOwner69
Gotcha!
I'm just ahead of you with my 69. I just got my cab on and interior in. I'm anxious too! Everything that moves in the front of mine is new and seems tight and is tough to turn by hand, but I'm turning the new tie rod ends, new idler arm, new pitman arm and new power steering gear. In my opinion, that's the way I want it at this point. I figure that that stuff is almost as easy to get to with everything back in place.
