03-31-2013, 10:42 AM | #1 |
What did i break?....
i have just finished my inline 6 to 350 swapi used my old 3 on the tree transmission but i converted it using the hurst mastershifter and the instalation kit and it always gave me problems but anyways im pulling out of my driveway and give it 3/4 throttle and shift into 2nd and let out of the clutch and everything starts grinding and jerking really bad. now everytime i try to move it it moves but it jerks and grinds in every gear...
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
03-31-2013, 11:24 AM | #2 |
Re: What did i break?....
It sounds like your shifter linkage is all out of adjustment and your not fully engaged into each gear to much slop in the linkages maybe?
03-31-2013, 12:57 PM | #3 |
it went in every gear fine before though i can put it in every gear and move it around but once you get over 5mph it starts grinding and jerking.
03-31-2013, 04:12 PM | #4 |
Sounds like you need to check that though just because it worked before doesn't mean it works now... You said you have had problems with the shifter before so it's a starting point and also check your trans mount see if it's still attached could be another issue
Posted via Mobile Device |
04-02-2013, 10:16 AM | #5 |
well, it turned out my transmission pretty much fell apart on the inside. put another transmission in and the shifter and everything works perfect.
04-02-2013, 10:34 AM | #6 |
Well...I guess that explains it.
(lol) K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-02-2013, 10:49 AM | #7 |
yeah i was freaking out then i found a old 3speed like i had for 100$ so i guess it wasnt too bad..
