upper a-arm swap side to side
Guys help me out. It seems that I read here at some point that I can swap side to side the upper a-arms to increase castor? I have a 70c-10. Is this true or do I need to be researching new arms all together? Thanks
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: upper a-arm swap side to side
I wouldn't do it.
Here's the thread that talks about it,... http://67-72chevytrucks.com/vboard/s....php?p=5073126 Ok. I had time to tinker so after swapping the upper control arms side to side. Here are the results. I think this debunks the thought that the uppers can be swapped. Yes, the caster is excessive and could be brought to 8 or 9 degrees by adding about 9/16" to 5/8" thick shims to the rear but the camber is already positive and can't be remedied. Time to swap the uppers back and notch the lowers....
I would use a set of Porterbuilt Fabrication tubular a-arms to help with caster.
thanks lolife99 this is the thread I had read.
