Old 03-31-2013, 04:01 PM   #1
savatreatabvr
savatreatabvr's Avatar
125vac switch in 12vdc application?
I'm wondering if using a push button 125vac 1/3hp switch to turn on and off a 12vdc radiator fan in my truck is safe or am I creating major issues?
savatreatabvr is offline   Reply With Quote
Old 03-31-2013, 04:52 PM   #2
mgchevyparts
mgchevyparts's Avatar
Re: 125vac switch in 12vdc application?
The amperage rating is what you need to pay attention to. You should have a relay installed and the control would go through that. You don't want to run, say 20 amps through the switch normally.
mgchevyparts is offline   Reply With Quote
Old 03-31-2013, 05:10 PM   #3
JellyBeanDriver
There is a difference between DC and AC ratings of switches and relays due to the AC arc when the switch opens extinguishes as the voltage crosses zero. Not so when switching a DC load.
So AC amps does not always equal DC amps. Also max voltage can be different.
Can't tell you if this would be a problem with your radiator fan but like the previous post, you could have this switch activate a relay.
JellyBeanDriver is offline   Reply With Quote
Old 03-31-2013, 06:00 PM   #4
savatreatabvr
I already had the 125vac push button switch laying around so I thought I'd be cheap and use it but rather than dealing with a relay I think I'll just go buy a 12vdc toggle switch from Autozone and save myself some headaches, lol! Thanks for the info.
Old 03-31-2013, 06:48 PM   #5
mgchevyparts
Doesn't matter, you need a relay for that much current.
Old 04-01-2013, 01:19 AM   #6
Pyrotechnic
Pyrotechnic's Avatar
Even if you do go to the parts store and get a 12V toggle switch and hook it up without a relay, you will fry the contacts out of it in no time.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-01-2013, 02:14 PM   #7
hatzie
Moderator
hatzie's Avatar
Way too much inrush current on a fan motor to just use a switch. GM uses a relay on the heater fan for this reason.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-01-2013, 06:07 PM   #8
savatreatabvr
I thought I was pretty good with wiring until I heard the word "RELAY"! Lol but I'll take ya'lls advise and use a relay if someone could tell me what relay to buy and how to wire it up?
Old 04-01-2013, 06:17 PM   #9
savatreatabvr
Old 04-01-2013, 10:54 PM   #10
JellyBeanDriver
Get a 'Bosch' style relay with socket. You can get them from ebay for cheap (I think I paid $14 for 5 qty).
Usually has 30A contacts and has a drawing on them that shows the coil terminals, the common and the normally open and closed contacts.
