Old 03-31-2013, 04:54 PM   #1
Painter D
Painter D's Avatar
Emissions delete question
This was on the top of my intake I assume it's emissions related ,if it is what's the best way to delete it? If it's something else or I need to keep it feel free to let me know. The motor is a 2003 LQ9 out of an Escalade.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 03-31-2013, 09:20 PM   #2
clinebarger
Re: Emissions delete question
EVAP purge solenoid. When using a factory engine vanity cover...I leave it.
clinebarger is offline   Reply With Quote
Old 03-31-2013, 10:17 PM   #3
Painter D
Painter D's Avatar
If I leave it do I need to plug it with something or just leave it open to the elements? I'd rather remove it and plug the hole in the intake, if anybody knows a good remedy for doing this feel free to let me know.
Old 03-31-2013, 10:33 PM   #4
dayj1
The purge valve is normally closed. So, you can just remove the hose from it and leave the valve connected to the intake. You can also run a pipe tap in the hole and use a pipe plug to close it off. I can't remember off the top of my head if it's a 3/8 or 1/4 pipe tap, but its obvious because only one of those sizes will fit in the hole.
dayj1 is offline   Reply With Quote
Old 03-31-2013, 11:15 PM   #5
Robznob11
Robznob11's Avatar
I removed it and bought a rubber oil plug from orylies. It works just like a rubber freeze plug but its only 1/2 round its like a mini. Looks a lot cleaner
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-03-2013, 03:51 PM   #6
1badcholo
I used an A/C compressor plug. It comes with a new A/C compressor outlet. I had one lying around. You cold probably just ask your local parts store to take one off a core. Good luck.
1badcholo is offline   Reply With Quote
