Old 03-31-2013, 05:07 PM   #1
Tukn22z
upper control arm hitting spindle
well im installing a mcgaudys disc brake kit with 2 1/2 drop spindles on a 1970 c10. The problem i am having is my upper control arm is hitting the top of the drop spindle. I've read people saying trim the upper control arm a little so it doesnt interfere but i feel like the upper ball joint isnt seating correctly in the spindle. Now i measured the widest part of the taper on the ball joint and it was around .708". I measured the widest part of the taper on the spindle and it was around .735". does this sound correct?
The ball joints im using are MOOG Part # K6024
These are the spindles :
http://www.summitracing.com/parts/mm...del/c10-pickup
heres some pics of the issue
Tukn22z is offline   Reply With Quote
Old 03-31-2013, 05:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: upper control arm hitting spindle
Do you have any weight on the suspension yet?
Keith
Convert to disc brakes.
Old 03-31-2013, 05:40 PM   #3
Tukn22z
i had the jack under the lower arm from when i installed the coil spring
Old 03-31-2013, 07:10 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
When you drop the full weight of the truck down, the suspension should cycle down enough to open up the gap between spindle and control arm.
Old 04-01-2013, 04:58 PM   #5
AustinScott
AustinScott's Avatar
I have the same spindles and I just didn't like when I jacked up the front I couldn't turn the wheels... so I fixed it by trimming the upper control a tad bit and smoothing out the top of the spindle.
Now that I have a lift in the garage, I'm happy I did this. My truck is on the lift a lot and it would be a pain if the front spindles were hitting
check it out in my photo build thread.
post#34 http://67-72chevytrucks.com/vboard/s...8&postcount=34
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 04-03-2013, 09:09 AM   #6
C5Phil
C5Phil's Avatar
got the same problem with my 70' - just installed my disc brake kit (McGuaghy's also) and took it down to have front end aligned- mechanic says it calls for .5 degrees camber but the best he can do is 1.9 degrees both sides- have you encountered the same issue?
C5Phil is offline   Reply With Quote
