Old 03-31-2013, 06:10 PM   #1
savatreatabvr
savatreatabvr's Avatar
Wiring a Fan to the 12vdc at Fuse Box?
Instead of running positive and ground wires from the battery to my switch inside the cab, can I run a wire from the positive 12vdc at the fuse box and a ground wire to the metal dash?
savatreatabvr is offline   Reply With Quote
Old 03-31-2013, 06:23 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Wiring a Fan to the 12vdc at Fuse Box?
Setup relay to power the fans. Use a ground switch to activate the relay. My probe grounds power relays to start up my fans.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-31-2013, 06:33 PM   #3
savatreatabvr
Can't I just wire a switch in the positive wire to kill power to the fan? Or in the ground wire?
Old 03-31-2013, 06:55 PM   #4
Wrecked1982
Wrecked1982's Avatar
electric fans draw to much amp. i needs a relay or the switch will melt
Wrecked1982 is offline   Reply With Quote
Old 04-02-2013, 06:44 AM   #5
wraprail
wraprail's Avatar
A relay is a switch that can handle loads with high current draw such a a cooling fan. Then you can use just about any switch you want to switch the relay. One advantage of a relay is you can mount the relay close to the battery and the fan with very short wire runs. Use large guage cable (# 12 min. 10 better) from battery, to an inline fuse to relay then to fan+. Run fan- to a good ground close to fan. (Frame or crossmember. Make sure you have clean bare metal). Now you can run small guage wire from the relay to whatever switch you want. You can use positive or negative to switch the relay. The best switch to use is a temperature switch screwed into the water jacket that turns the fan on and off automatically. You can get one on ebay for less that $20. Then you can add a switch over ride for manual fan control. Thats what I do. Relays are cool. Once you understand how they work and what they can do you find all kinds of uses for them.
Just think of a relay as a remote switch that you switch with a switch.
Oh yeah, as stated above if you just use a switch and no relay you will either burn up the switch or the wire running to it or your fuse box will melt. When you have long runs of wire you have voltage drop. By the time you go from the battery to a switch inside the cab and back to the fan you would be like 9 or 10 volts at your fan. If the wire or switch somehow didnt fry your fan will get hot and burn up cuz of the low voltage. With a relay you have short wire runs and almost no voltage drop.
Ok thats enough.
Later.
wraprail is offline   Reply With Quote
Old 04-02-2013, 07:36 AM   #6
Remon.
Remon.'s Avatar
Great explanation! Thanks
Remon. is offline   Reply With Quote
Old 04-02-2013, 06:15 PM   #7
savatreatabvr
I agree, the "RELAY" finally makes since! Thanks wraprail!
Old 04-07-2013, 09:19 AM   #8
wraprail
wraprail's Avatar
Wow, No problem. Glad I could help!
