Lowering block geometry
For a coil spring rear, if all things remain the same and the only thing you do is install lowering blocks, does the axle get closer to the frame? For example the difference between 4" lowering springs and 6" lowerings springs would be 2" from the axle to the frame. If you were to install 2" blocks with 4" springs would you have the same axle/frame clearance as 4" or 6" spring?
Posted via Mobile Device |
Re: Lowering block geometry
I've never seen a lowering block for a coil spring suspension.
Blocks only lower a leaf sprung truck if the leaves are under the axle. If the leaves are above the axle then block will lift the truck. I have seen circle spacers to go above or below a coil spring, but they all lift a truck, none will lower a truck on a coil sprung truck.
2001 ![]() Last edited by TexasSteve; 03-31-2013 at 07:53 PM. |
Yes the blocks will move the axle closer to the frame...on a coil spring truck the blocks go between the trailing arm and the axle....you will need longer U bolts also
![]() Join Date: Jan 2011
Yes, the blocks decrease axle to frame distance just like springs.
Everyone makes them... http://www.performanceonline.com/60-...ock-kit-PO204/ http://www.classicperform.com/Store/...Truck/CP45.htm http://www.brotherstrucks.com/products.asp?dept=671 |
How are people deciding anything about them not knowing his truck? I see nothing indicating what truck he even has.
I see posts like this around this site....Asking questions regarding something truck specific without anything saying what truck they are working on. How do you guys find a solution without knowing the truck? I looked at the links provided by T Smith & blocks for trailing arms are being referred to as coil spring blocks?
2001 ![]() |
These trucks only came in 2 versions, leaf springs or coil spring on trailing arms
#7 | |
It'll be different if this question was in a specific year range Forum, but it isn't. It is in the General Suspension area. His Post doesn't even mention a trailing arm so......
2001 ![]() |
67-72 parts collector,…
![]() Join Date: Nov 2002
And he said,... "for a coil spring rear",...
Senior Car Nut
![]() Join Date: Jan 2008
TexasSteve, what year chevy truck has rear coil springs without trailing arms? I mean, I don't know my new trucks, so maybe I'll learn something here.
Larry |
#10 | |
Is it ok for me to laugh if he comes says & says it it a custom build which is why it wasn't posted in a year range specific section? :P
2001 ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I went by his previous posts which say he has a 70 model C10. Therefore, the discussion here is pertinent and accurate.
Somewhere on here, there is an FAQ article I wrote years ago concerning building your own lowering blocks if you're so inclined. Yes, the blocks will decrease the axle to frame distance the same as a drop spring would. One advantage of lowering blocks though, is that you gain the drop you desire without messing with shock absorber length or geometry, unlike using a drop coil spring. If lowering blocks are used in conjunction with drop springs, you get a net drop of the combination of the two (ie, 2 inch spring plus 2 inch block equals 4 inch drop), but your stock shocks will still work and you won't need relocators like you would if you used a pure 4 inch drop coil spring. |
#12 | |
Senior Car Nut
Larry |
#13 |
I may be off an inch or so here but y'all can correct me, one thing to keep in mind when using blocks 2" or thicker is that if you have a flat tire hard stuff will hit the ground before the rim if you stay with 15" wheels, not an issue with larger rims say 17" and above.
#14 |
Two inch blocks are about as far as you want to go to avoid scrub line issues. Plus, the truck looks funny from the rear if you go too large on the blocks.
Posted via Mobile Device Last edited by Tx Firefighter; 04-01-2013 at 11:32 AM. |
#15 |
Or even better (imho).....There shouldn't even be a General Suspension area. Each year range should have its own sub-Section for Suspension I(and engine/exhaust/etc.).
2001 ![]() |
#16 |
He's basically asking is, does 2+4=6 to which the easy answer and only answer is yes.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by lolife99; 04-01-2013 at 06:58 PM. Reason: cleaning up thread |
#17 |
I think we all got off on the wrong foot in this thread.
This is a great place to learn and share info. I think the OP's question has been answered.
#18 | |
I don't see where it is that you answered the OP's original question in your initial response w/o making your own assumption. Several on here do know that there are lowering blocks made for coil spring suspension applications. Take a step back. No need to leave....
