03-31-2013, 08:00 PM | #1 |
GM NOS Moulding/Door Fuzzys/ Parking Brake Cables/AC Adapter
1 set of Inline Tube coil spring 2wd parking brake cables #RE-416 40 1/2" long.
$50 each new - $75.00 shipped Nostalgic Air GM Compressor Adapter #GM1600, #8 &10 outlets All seals included $30 shipped 1 GM NOS RH Rear Bedside Moulding #3997432 Comes with GM clips. Has shelf wear, discoloration of the black paint in some areas, some yellow spots that 2come off with fingernail. Piece is straight just needs some tlc. $30.00 shipped 2 GM NOS Inner Side Glass Anti Rattle strips. These clip inside the passenger side door in between the door and the glass. Never been opened GM #3893782 $25 shipped each. Set of window fuzzies and rubber outer seals...looks to be left and right outer and 2 of the left or right inners. These came with some other NOS parts but the packages were deteriorated to pieces. I am not sure if these are GM. I do not see any markings of any kind on them. Need to be cleaned. I didn't want to throw them away, maybe someone can clean them up and use them. See pictures. Sold as is. $35.00 shipped for the (4) pieces. Set of 2 door channel run seals. These are the same deal as the fuzzies above, came with box of Gm nos stuff but I do not know for sure. Need to be cleaned, not in excellent condition but they are still pliable. $30 Shipped for the pair. Will trade up or down any of the above for 69-72 ignition switch spacer in good condition, nos or aftermarket name plate that goes above the ignition switch, Center AC Vent, NOS outer door handles, NOS hood hinge springs, or Factory Antenna Set Up. Thanks! |
03-31-2013, 08:04 PM | #2 |
Re: GM NOS Moulding/Door Fuzzys/ Parking Brake Cables/AC Adapter
interested in the ebrake cables. year range? i need them for a 68
03-31-2013, 08:04 PM | #3 |
If its window channel felt, ill take it
Posted via Mobile Device |
03-31-2013, 08:06 PM | #4 |
03-31-2013, 08:09 PM | #5 |
They are the pieces that snap inside the door, not the vertical channel.
03-31-2013, 08:26 PM | #6 |
I'll take lower rr trim
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
03-31-2013, 08:36 PM | #7 |
Trim Sold Pending Payment
03-31-2013, 08:56 PM | #8 |
Payment sent for rr lower trim
03-31-2013, 08:57 PM | #9 |
Nevermind, thought it was someething else.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
03-31-2013, 09:56 PM | #10 |
Inline Tube shows the rear coil spring 2 wheels drive cables to be the same for 67-72.
03-31-2013, 11:08 PM | #11 |
I'll take the window fuzzies # 3893782 for $25 ea shipped. PM payment info. Thanks, Dan
03-31-2013, 11:29 PM | #12 |
GM Window Fuzzies in packaging SOLD.
04-02-2013, 11:11 AM | #13 |
I'll take the e brake cables
Can you tell me how wide the rubber is on the 4 piece fuzzy/seal for 35? If it is 1/2 to 3/4 and not torn I will take those also Pay pal? Posted via Mobile Device |
04-02-2013, 06:03 PM | #14 |
Sale pending on cables, Waiting on payment from Mo. Stickman you are next. Pm sent.
04-02-2013, 10:46 PM | #15 |
Parking brake cables sold!! Stickman call me and make sure that is what you need. Thanks!
