03-31-2013, 10:51 PM | #1 |
A-arm bushing question '65 chevy pickup
I recently purchased new powder coated upper and lower A-arms complete with bushings and ball joints to save time and money while rebuilding the front end and adding disc brakes to the front. My question is, how tight are the bushings supposed to be to turn? I began the assembly today and, I needed to turn the lower bushing to index it to the round dowel that locates it side to side. I had to take a pipe wrench to do this and even then, I could barely turn it. Is this normal? Thanks for any help.
04-01-2013, 10:38 AM | #2 |
Re: A-arm bushing question '65 chevy pickup
Sounds like they were over tightened.
04-01-2013, 10:43 AM | #3 |
The powder coating is much thicker than paint...maybe this caused the tightness?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-01-2013, 10:47 AM | #4 |
Always remove powder coating from threaded components and pin holes, etc. You should be able to turn those steel bushings in with a regular length wrench.
04-01-2013, 06:31 PM | #5 |
Thanks everyone for the replys.
