Old 03-31-2013, 11:10 PM   #1
jcblue
jcblue's Avatar
Porter built hinge guys..? Hood spring
Have you guys had trouble getting your hood open? I'm thinking of fabing some sort of hood spring so it will pop up and I won't have to wedge my fingers between the grille and hood to open it.. Pics would be great
jcblue is offline   Reply With Quote
Old 04-01-2013, 01:02 AM   #2
rpatowers
Re: Porter built hinge guys..? Hood spring
I had the same problem. I would release the hood and it would only pop up about 1/2" and I'd have to wedge my fingers between the hood and grille and lift it up. I replaced the old hood springs with new ones and now everything works very well.
rpatowers is offline   Reply With Quote
Old 04-01-2013, 12:39 PM   #3
jcblue
jcblue's Avatar
Ttt
Old 04-02-2013, 07:00 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
A while back I messed around with adding a spring to the pivot post like some cars/trucks have but the hood wouldn't shut with it so I gave up.
You could add a spring to the top of the support or similar would work. Some 70's GM cars had that.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-02-2013, 10:50 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Make sure all the hood hinge pivot points are well lubed.... it might solve your problem.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-24-2013, 11:27 PM   #6
Del72Chevy
Del72Chevy's Avatar
ive got the same problem trying to pry the hood open with my fingers. there is a spot that looks like a little spring would pop in but have not been able to find that little spring anywhere
My Build Thread
http://www.67-72chevytrucks.com/vboa...d.php?t=531309
Del72Chevy is offline   Reply With Quote
