Old 04-01-2013, 12:10 AM   #1
Jsieger89
performance powerstearing?
power stearing is leaking on my 87 is there a upgrade available for replacing this
Jsieger89 is offline   Reply With Quote
Old 04-01-2013, 12:14 AM   #2
Tdubbyount
Tdubbyount's Avatar
Re: performance powerstearing?
Where is it leaking from? How bad is it leaking? What kind of performance upgrade are you looking for? Very vague question you have here.
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one.
1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose.
Tdubbyount is offline   Reply With Quote
Old 04-01-2013, 12:25 AM   #3
kalbert
Simple answer is no, there's not a factory bolt on quick ratio box or anything. There are some aftermarket quick boxes available but they aren't cheap. I also think I've heard of people using the smaller box from an S10/F/G/A body but I don't know that it was worth the trouble. There's also rack and pinion kits available (or piece together you're own), but again not cheap and in the end I don't know if it's worth doing or not. Any details you can post about the problem will help people give better answers though.
kalbert is offline   Reply With Quote
Old 04-01-2013, 09:26 AM   #4
Jsieger89
the problem is my power stealing pump is leaking so I am going to replace it, I was just curious if a power stealing pump is a power stealing pump or if there was aftermarket pumps that might perform better. What would be the advantage to puting a smaller box in from a s10? also what could I take a rack in pension out of at a pick in pull that would be a nice upgrade for me?
Old 04-01-2013, 10:39 AM   #5
Jsieger89
it is leaking from the top were the stealing colon goes in. Not leaking to bad but bad enuf that it makes a mess and pisses me off. I was originally just wondering if there was anything I could replace it with that would be better then what's there but I am interested in any way I could increase handels
Old 04-01-2013, 11:45 AM   #6
silvereagle07
silvereagle07's Avatar
Here's a link to the AGR super box sb2. http://www.agrperformance.com/Gearbo...sports.htm#SB2
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-01-2013, 12:06 PM   #7
kalbert
A power steering pump is for the most part a power steering pump. Some of them have different valves to provide different levels of assistance, but they need to be matched to the application. It's not really a performance part. Replacing the seals in it is relatively easy with the right tools, else a remanufactured unit is probably the way to go and not real expensive.
Some of the smaller boxes found on S10's and such have a quicker ratio (eg turning the steering wheel 1/4 turn moves the wheels further with a quick ratio box than a standard one). Rack and pinion is generally lighter weight & gives better feedback and usually has a faster ratio as well. Both are pretty involved swaps requiring some fabrication and alot of money, there aren't any factory parts that will just bolt on. I believe UniSteer makes a rack and pinion kit.
Old 04-01-2013, 12:56 PM   #8
69GMC910
MOTORHEAD!
69GMC910's Avatar
Anybody running the AGR one?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-01-2013, 05:13 PM   #9
silvereagle07
I was just searching the site and read an old thread saying the gears are the same as the stock steering gear rebuilt but with different fittings (captkaos) http://67-72chevytrucks.com/vboard/s...d.php?t=429565. Now I'm confused. I was looking into that one to replace mine. Someone else suggested Red Head Steering Gears.
Jeramy
'85 Chevy 4X4 SOLD
