Old 04-01-2013, 09:39 AM   #1
kikkegek
kikkegek's Avatar
play on pitman shaft of power steering
guys, some help please.
I recently started hearing a "BOINK" when turning the car in the street. Couldnt find what is was till last week.
found that the pitman shaft moves up when steering to one side and then drops (BOINK) when I start turning to the other side.
I made a picture and added some arrows to make things clear:
the big arrow point to the pitman shaft
the vertical arrow shows the direction of the play on the axle.
I didnt measure it, but its like only 2-3mm and outside the car you can only see the play, but not hear it.
when you are in the car, you can hear the BOINK very clearly.
I already tried to looses the retainer nut on top and used a allen key to turn counterclockwise a quarter turn. tried that three times, but didnt seem to solve the play on the axle.
any ideas?
kikkegek is offline   Reply With Quote
Old 04-03-2013, 09:20 AM   #2
kikkegek
kikkegek's Avatar
Re: play on pitman shaft of power steering
he guys....
HELP!
I made a video to check if the screw for the pre-load adjustment was still working. You know the one op top.
as you can see on the video when I turn the bolt on top, the pitman shaft moves up and down. so that is still working.
what else can cause this play on the shaft? anybody know?
here is the video: you got to play it full screen to see the movement:
http://youtu.be/exMBKlTqUy8
Old 04-03-2013, 12:09 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
It may be time to replace the steering box.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-03-2013, 12:41 PM   #4
kikkegek
kikkegek's Avatar
I am thinking about rebuilding it. a kit seems cheap and I am not afraid of a little challenge. But first I want to know what might cause my play in the shaft.
Old 04-03-2013, 03:46 PM   #5
INSIDIOUS '86
4x4 boxes were bigger than thier 2wd counterparts mostly because the took more stress. So it may be simply worn inside or something started letting honor a bearing or such has let go. Is there any shops that can rebuild steering boxed where you live?
Old 04-03-2013, 03:48 PM   #6
kikkegek
kikkegek's Avatar
hahahaha...no such luck....
driving a square is considered driving a museum piece over here. So no shop rebuilding stuf like this. Rebuilding engines yes...but rebuilding gearboxes no...
I can do fine myself...probably gonna go ahead and order a rebuild kit
Old 04-03-2013, 04:28 PM   #7
INSIDIOUS '86
Tell us how it goes!
Old 04-03-2013, 04:31 PM   #8
kikkegek
kikkegek's Avatar
but before that I want to make sure that a rebuild kit will fix my problem.
I dont see how this vertical play will be fixed by a rebuild kit.
Old 04-03-2013, 07:35 PM   #9
INSIDIOUS '86
I'm not to familiar with the insides myself other than a wizard lives inside with many giants that push a bar
Old 04-04-2013, 03:31 AM   #10
kikkegek
kikkegek's Avatar
bwahahaha...
Old 04-04-2013, 03:49 AM   #11
Remon.
Remon.'s Avatar
It's not that bad. I see them every day Did you already contacted Willem? If it's only a slightly common problem he would know some about it. And otherwise he may be having a spare...
Remon. is offline   Reply With Quote
Old 04-04-2013, 03:52 AM   #12
kikkegek
kikkegek's Avatar
yes I was thinking about driving up to Willem or Blazerparts next weekend if I can find the time.
