Old 04-01-2013, 01:25 PM   #1
tismy55
Installing 4x4 axles onto 65 frame
I have a 65 chevy swb and complete 72 K5 axles,,hangers, leaf springs. My question on my 65 frame where the radiator bracket is riveted to the frame, could I install the front spring hanger from the K5 in the same holes and use the K5 radiator bracket to mount my radiator.
tismy55 is offline   Reply With Quote
Old 04-01-2013, 11:02 PM   #2
tismy55
Re: Installing 4x4 axles onto 65 frame
Can Anyone respond ..Thanks
Old 04-01-2013, 11:38 PM   #3
'63GENIII
'63GENIII's Avatar
I've been looking at mine the same way. I don't have my hangers yet but if the new bracket keeps the front spring eye in the same location as the original and supports the radiator support the same as original, I don't see why not. My radiator support sits roughly 1-1/4 inches forward of the center of the spring eye. Where does the 72 hanger place everything?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-02-2013, 12:30 AM   #4
tismy55
It was in the same position as my truck before i cut them from the 72,Also I measured the centerline on my truck it was 23.5 same as the 72,,the leaf spring is 47" half of that is 23.5 should bolt right in same spot. I was just interested if someone has done this before. I was told to get 72 hangers and they would bolt right in,thats the only place for the front hangers to bolt to.
Old 04-02-2013, 03:06 AM   #5
padresag
if you look at Jon's installation like has been mentioned to you , you will see how it goes. you have to modify the rad support a bit
ron
padresag is offline   Reply With Quote
Old 04-02-2013, 10:06 AM   #6
tismy55
ron I look at the other build ,he used 89 4x4 hangers they are not the same as 72 hangers, the 72's are a good match only the cushion mounting holes are a little bigger.
