Old 04-01-2013, 02:31 PM   #1
ACK
ACK's Avatar
HEI Distributor for 4.1L 6cyl
This months project is switching over to an HEI distributor. I'm on a limited budget and want to know if you have opinions about the set up I'm leaning towards:
- Cardone Remanufactured distributor for 1978 Chevy 4.1L
- ACCEL Perform distributor cap and rotor kit
- Duralast ignition coil
I'm hesitant about buying an inexpensive eBay distributor and my shopping list is about the same cost as a Pertronix Ignitor II, so might as well get the real deal. Thanks for the input.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 04-01-2013, 03:30 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: HEI Distributor for 4.1L 6cyl
I have a Petronix Ignitor in my 64 with a 292 and I love it. That truck can set for months and fire right up with no problems. I also love the fact that it looks completely stock.
TBONE1964 is offline   Reply With Quote
Old 04-01-2013, 04:42 PM   #3
luvbowties
luvbowties's Avatar
Exclamation Re: HEI Distributor for 4.1L 6cyl
You'd still be leaving the better system on the table, imo. Pertronix would be my choice.
Sam
luvbowties is offline   Reply With Quote
Old 04-01-2013, 05:41 PM   #4
slepysal
slepysal's Avatar
I agree no big head cap, and easy as an ignition point swap!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-01-2013, 07:14 PM   #5
ACK
ACK's Avatar
The truck will be my daily driver by summer, so my biggest concerns are reliability and gas mileage. I read a lot of threads about Pertronix and it's hard to separate fact from opinion. What pushed me away was Pertronix' website inferring the Flame-Thrower coil is needed to get full benefit of their product – which makes the HEI more attractive to my wallet.
If you have the Ignitor, I would like to know how long you've had it, if your gas mileage noticeably increased, and did you upgrade the coil.
Old 04-01-2013, 09:33 PM   #6
slepysal
slepysal's Avatar
Ive had mine for over 6 years and have had ZERO issues I did upgrade the coil but only becuse I had a MSD blaster coil . I did have to use a ballast resistor.
In the end it is your choice , and your $$.
I went with the pertronix becuse :
1) easy install
2) It kept the "retro" look I wanted
3) No need to remove old distributor and mess with timming
4) the price was right
HEI or pertronix either way you'll be happy with the upgrade.
Old 04-02-2013, 08:13 AM   #7
ACK
ACK's Avatar
Originally Posted by Woogeroo View Post
Reading the HEI section in the FAQ, I was under the impression an HEI would drop right in, no mods needed. Am I wrong and need to adjust the shoulder?
Old 04-02-2013, 10:19 AM   #8
boucher racing
boucher racing's Avatar
I am running a Skip White HEI. I have put a advance kit in it and it has been flawless.
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 04-02-2013, 10:55 AM   #9
1963c-10
1963c-10's Avatar
I run the Pertronix II in my 63 230L6, did upgrade to a stronger coil (Summit chrome coil, supposed to be an upgrade over stock coil), no ballast and has run flawlessly for over a year. Did see 1-2mpg better than the stock setup. Easy to install and fits nice under the stock cap.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-02-2013, 12:25 PM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If you want one of the authorities of the Chevy Inline 6, Langdon's is the place. I bought my HEI (coil in cap style) from them.
http://stoveboltengineco.com/catalog...=0&sort=normal
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-03-2013, 12:01 AM   #11
Captainfab
60-66 Nut
I have not made the upgrade on a I6 yet, but a HEI designed for a 250 (4.1) 6cyl should drop right in your 250 6 cyl engine. You'll just have to change your wiring as per a typical HEI upgrade.
Old 04-03-2013, 06:05 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The HEI is a drop in conversion. Yank the old stuff out, drop in new HEI, supply it with a good power wire, install new plug wires, and gap your plugs to .045. I've done it to every six cylinder truck I've ever owned.
You'll be very happy. They start, run, and idle so much better.
