Old 04-01-2013, 03:42 PM   #1
Low_Life86
Low_Life86's Avatar
getting a little more pep out of my 305
whats up guy i was just wondering how i could get some more power out of my little 305 right now its mostly stock its a quadrajet carb with a K&N filter on it. it has headers and custom exhaust other than that its mostly stock anything i can do to get some horsepower out of it for as little cost as possible
Jeremy
'86 GMC 1500 dropped 6" in the front and 6" in the rear
2003 Land Rover Discovery
Low Life
Low_Life86 is offline   Reply With Quote
Old 04-01-2013, 03:52 PM   #2
Damon23
Damon23's Avatar
Re: getting a little more pep out of my 305
Cam and intake, other than that I think it would get expensive.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 04-01-2013, 04:06 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Give it a little more timing. Use a cooler thermostat but not don't run it too cold. Swap intake for a dual plane intake.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-01-2013, 04:19 PM   #4
Damon23
Damon23's Avatar
Good call on timing. I was under the impression that a small block gm likes 190-210 degrees as far as temp.
Old 04-01-2013, 04:52 PM   #5
Psycho_SWB
75-shot of nitrous
Psycho_SWB is offline   Reply With Quote
Old 04-01-2013, 10:05 PM   #6
kalbert
Assuming you'e starting with a solid motor, doesn't foul plugs, use alot of oil, rattle inside, etc. Get yourself one of the $70 SpeedPro 204/214 cams, a Performer (or equivalent) intake, gasket match the ports on the head (while the cam is out and the valves are closed so crap doesn't get down there... blow out when done) and a tune up (plugs, wires, cap, rotor if needed, add a little timing, and fine tune the carb) You'll be into it $200-$250 or so and a weekend or two but you'll notice a difference.
kalbert is offline   Reply With Quote
