Old 04-01-2013, 05:01 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink One step closer...
Got the new front bearings and brakes all installed on the front spindles of the truck. Was going to put drilled slotted rotors on it but couldn't find a set that would fit the wheels without having them turned down. I may try after the Pour Tour but for now just regular ones will have to do.
Also got the new compressor hooked up and the truck is now able to pump the rear and soon to be front helper air bags all on it;s own from the cab.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-01-2013, 05:30 PM   #2
MSHax
MSHax's Avatar
Re: One step closer...
Congrats! I love when parts start coming together, you get that almost sense of accomplishment. You're kinda lucky with the 71 C10, there are a bunch of brake options. I've got a 70 C20, if you don't want to switch to 5 or 6 lug, there's really only 1 choice, it's CPP or.... well CPP.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
MSHax is offline   Reply With Quote
Old 04-01-2013, 07:23 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: One step closer...
Got a few more things I'm waiting on but most of it is done for now. The tour is coming up fast and I need the truck ready which it is except for the small stuff.
Called speed hut today they said they should be shipping my gas guage back one day this week.
