Pulsing oil pressure.... a bad sign?
Hey all... something i've noticed on my oil pressure. When the engine is warm, and at low rpms (under 1000), the oil pressure pulses. I noticed it when I first bought the engine (olds 455), but now it seems to be getting worse. I don't know for certain when the motor was rebuilt, but there isn't a bit of grit or buildup on the rocker arms/valve covers, so I would guess not too long ago.
Usually, as you increase the rpm's, it smooths out, but now, it seems to be sticking around more.... also, it is fine when the motor is cold.... smooth at all rpms.... any thoughts???? Thanks!! ~Sean |
Fabricate till you "puke"
If its not making any funny noises, I would suspect a sticky bypass valve in the oil pump. I have seen that on a BB Olds, that was fresh(that I checked clearances on assembly). The BB Olds is a runner, but the oiling system is the biggest issue to deal with. I ran a Melling hy vol pump, with a Toronado pan/ windage tray, & main restrictors. valve train geometry gets to be fun with the big cams also......but that big Olds will make a 4000 lb truck flat smoke the hides at 100mph pulling high gear on an auto trans.......(you know, I hope it goes straight!) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
No, there are no funny noises.... I suspect it has a high volume pump, it runs over the 3/4 mark on our chevy guages....
is the bypass valve servicable? Or time for a new pump? might as well put on a chrome pan while I have it off right? chrome makes it faster? ![]() thanks! ~Sean Last edited by Stainless; 06-19-2003 at 05:49 PM. |
Chrome = Bad.
Let me tell you why. The big reason is that it doesn't dissapate heat very good. Chrome becomes rusty very easy. And cheap chrome is hard to seal. (leaks) Chrome looks nice and all, but unless it's a air filter lid, it will not be under the hood of my truck. I am sometimes known as the ainti-chrome. ![]() |
2nd that,I dont have much use for chrome!you wont see it under my hood either
its all about the +6 inches
Also, if your chrome pan has ANY chrome on the inside (some cheap ones do) and your pan smacks the ground, you can have chrome particles floating in your oil.
Not good. How long has your oil been in there? I have seen oil that needed chainged do this. |
I just changed the oil last weekend.... less than 200 miles ago.... the only thing that's changed since the oil change was my oil pressure dropped a little... just a thinner oil I suspect.... (it still had the oil from when I bought the motor)...
~S |
