Old 04-01-2013, 08:59 PM   #1
Jsieger89
What is this
What is the circle thing in the bottom right hand corner of this pic, it's in my way lol
Jsieger89 is offline   Reply With Quote
Old 04-01-2013, 09:00 PM   #2
Jsieger89
Re: What is this
Whoops the way it put the pic it's kinda top right
Old 04-01-2013, 09:09 PM   #3
broey
Square
broey's Avatar
Re: What is this
looks like the charcoal canister, it helps with fuel fumes odor.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-01-2013, 09:13 PM   #4
mongoose
mongoose's Avatar
Re: What is this
vaccum ball for the brakes?
or the stud for the jack.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-01-2013, 09:17 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: What is this
That's the vacuum reservoir for the AC/heater controls..... Removing it will cause air flow through the vents to change top to bottom etc. as engine vacuum drops under acceleration or loads (going up hills).....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-01-2013, 10:37 PM   #6
Jsieger89
Re: What is this
can I relocate it? I'm sry but I'm still a little confused what will happen if it is removed
Old 04-01-2013, 10:43 PM   #7
broey
Square
broey's Avatar
Re: What is this
ahh.. looks like the charcoal canister I had In another truck.
Old 04-01-2013, 11:52 PM   #8
J Knight
J Knight's Avatar
Re: What is this
This^^^
Your a/c blend doors are controlled with vacuum. The ball stores vacuum, if you are still running your stock a/c system you need the ball to operate the vents and yes you can relocate it.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-02-2013, 12:13 AM   #9
Jsieger89
Re: What is this
I AWSOME as long as it is put back upright and level I'll be ok?
Old 04-02-2013, 01:41 AM   #10
spencer_41188
spencer_41188's Avatar
Re: What is this
you can put that puppy where ever and however you wont as long as the vacuum lines are hooked up
if its not hooked up all your vents will blow hot air ..... witch reminds me I have to hook mine up
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
