Old 04-01-2013, 11:34 PM   #1
mgold97
Autometer mechanical guages
Just bought a set of autometer mechanical gauges(oil/water). Will be going with copper line, but cant find any posts on how to wire them. There are only 2 red and 2 blacks wires, so should be easy. Any help or pictures would help.
1984 c10 (350/th350)
mgold97 is offline   Reply With Quote
Old 04-01-2013, 11:41 PM   #2
mongoose
mongoose's Avatar
Re: Autometer mechanical guages
what series? those wires are just for the lights id assume.. red to pos.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-01-2013, 11:51 PM   #3
bigblock73
yeller
bigblock73's Avatar
should be two wires only (black and white), for the illumination...the hard line will make the gauge read. that is how my mechanical Autometers are set up.
bigblock73 is offline   Reply With Quote
Old 04-02-2013, 12:18 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i'd want the lights to work when the stock ones are on so
I'd use the grey going to the cluster plug for light +
some may even have a fuse box spot
and black to the ebrake grounding bus
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-02-2013, 03:34 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Soldered mine to the printed circuit to the bulb lines and common ground
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-02-2013, 05:24 PM   #6
mgold97
which fuse or wire should I tap into for lights? can I combine two red wires and plug/splice them into one + source?
Old 04-02-2013, 05:39 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
yes add the reds together and the blacks together ,power is number 2 grey
I'd run the neg somewhere else,away from this plug
the neg all goes down to one wire back there anyway
John
Old 04-02-2013, 08:33 PM   #8
mgold97
84 has same plug? What size wire should I use to splice into 2 if my + wires too short? Thanx for all this info guys.
Old 04-02-2013, 08:43 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
82 should have the grey in 2
safe bet would be at least 20AWG for patch wires
if you can't get that one the grey going to the radio plug would be an ez grab too
has three wires
radio power yellow
grey dimmer<-----this one
black radio ground
John
Old 04-02-2013, 08:46 PM   #10
mgold97
Don't have radio in mine lol.
Old 04-02-2013, 09:13 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
does it have the wires?
John
Old 04-02-2013, 09:15 PM   #12
mgold97
will have to check in a bit.
Old 04-02-2013, 09:58 PM   #13
mgold97
Took a look and I do have stock radio plug with 3 wires as described. Since I don't plan on putting tunes in can I just go straight to black and grey wires as + and ground? do I need to have any kind of fuse in between?
Old 04-02-2013, 10:06 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
no should be fine
grey and black will dim as normal
John
Old 04-03-2013, 12:28 AM   #15
LynnJr
Here is my dash with autometer gauges.Still need to add the tach.
LynnJr is offline   Reply With Quote
Old 04-03-2013, 10:08 PM   #16
mgold97
Got it all in buttoned down, so should work. Still waiting on radiator and headers, so haven't started my engine yet. Thank you all
