Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-02-2013, 12:03 AM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Need help finding wheels!
I need to find some 15x10 5x5 4.5/5" BS rear wheels and some 15x4 or 15x5 5x5 front wheels. I havent had much luck other than seeing some Weld Rod Lites which I'm not a huge fan of... Can somebody point me in the right direction! I need the wheels to get my slicks on before mid May! Prefer aluminum, weight is an issue!
Thank you!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-03-2013, 11:24 AM   #2
redsled87
redsled87's Avatar
Re: Need help finding wheels!
Centerline convo pros have a 5 on 5 pattern with a 5 " backspacing on a 15x10. They alson offer a 4 and 6 wheel for the front. You could also redrill your axles on drums for the car paatern too. Depending what spindles you have, you can use Camaro rotors on the front.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 04-04-2013, 05:22 PM   #3
funnyfarmracer
Rocket wheels from speedway has a few to choose from.
funnyfarmracer is offline   Reply With Quote
Old 04-04-2013, 08:52 PM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
Thanks guys... What do you think of 5 spoke wheels being used on the rear for drag racing? Safe?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
