Heat shielding on a budget?
Do you guys actually buy the Thermo-Tec heat sleeves for your lines and plug wires? That stuff is so dang expensive!
There has to be a better a way.
1982 GMC C1500 4x4 w/ 305 and sm465. 2002 Kawasaki Ninja 250. 2007 Dodge Nitro. |
Re: Heat shielding on a budget?
Bump.
Anyone?
I've seen some but it all still seems so overpriced for what it is.
those little silver 6" sleeves are HiGh$ . 4 for 40.$$ at summit.
I like the Black rubber fire sleeve, by DEI in 3ft length for 40.$$ better http://www.summitracing.com/parts/de...4/media/images |
See? That's what I mean. $40 for 3 feet of a wire sleeve? Seems so ridiculous to me.
For your plug wires? A wire loom is a cheap and good looking alternative for that.
Also good wires that are thick and heat resilient can help and they last plenty long Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
This is my hot tip of the week..!
If you have a Pic-A-Part type yard near you, just check out late model cars. Many newer cars have lines and hoses that run close to converters and such and use the good heat shild products. The fuel lines usually have some.. In fact the auto makers use the best heat shield made in most cases. Stuff usually don't go bad either. And it's normally free since it fits in your pocket! That's what I do..
