Old 06-19-2003, 07:54 PM   #1
kevins67gmc
kevins67gmc's Avatar
67-68 gear shift lever question
I need to know are the 67-68 3speed manual coloum shift and auto gear shift levers the same.
kevins67gmc
Poulsbo,WA
kevins67gmc is offline   Reply With Quote
Old 06-19-2003, 09:38 PM   #2
Don Smith
The three speed column shifter is shorter and slightly smaller in diameter and has bend in it but the end that goes into the column is the same as automatic column and will work and looks better than the long automatic shifter to me.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 06-19-2003, 10:59 PM   #3
matt_field
matt_field's Avatar
if you need a 3 speed shifter for a 67-68 i have one
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
