04-02-2013, 08:51 AM | #1 |
Trailing Arm Separating
As I was waiting on my rear coil spring clamps to arrive from LMC, I decided to clean up the trailing arms a bit. I noticed the right side (passenger) was separating about 1/4 inch on the underside forward of the differential. As a temp solution I used the existing holes in the trailing arm and bolted it together in three places in front of the differential. Then I noticed that the very rear of the trailing arm (behind the differential) is separated by about 1/2 at the bottom. There is no existing hole there to do a temp bolt repair. Pics below. 1st is the right side that is separating, 2nd is the left side, which is not.
I did a forum search on "trailing arm separating" and found the most common solution is to remove them, clean them up and weld them back together. The questions: -Is this a problem that I can safely push off till mid-summer? Or is it critical that it be fixed NOW. I drive it several times a week. -Would a decent temp repair be to: Loosen the U bolt so it is not binding the arm and drill a 1/2 inch hole between the rear of the trailing arm and where the U bolt goes through and use a grade 8 bolt? -Is my temp solution of bolts anywhere on the arm a bad idea? -If it needs to be fixed now, is removal, clean up and welding them back together the way to go? Any thoughts or advice would be appreciated. |
04-02-2013, 09:01 AM | #2 |
Re: Trailing Arm Separating
I think I'd find a replacement OEM trailing arm and just swap it out. Sooner than later .. I have seen worse though.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
04-02-2013, 12:57 PM | #3 |
see if you can find a set of 3/4 ton ones they are plated on top and bottom. i got a set of 3/4ton ones and what was'nt plated i welded them up
04-02-2013, 04:40 PM | #4 |
Or weld plates on yours. I bought some rust free trailing arms from another forum member that have zero rust but are separating. I plan on getting some 1/8" thick flat stock and welding it on top and bottom.
Bud |
04-02-2013, 06:19 PM | #5 | |
Posted via Mobile Device |
04-02-2013, 06:54 PM | #6 |
this is what i did to mine
04-02-2013, 08:20 PM | #7 |
I was going to make a cardboard or paper template and run it full length top and bottom. I would make the proper holes for the u bolts in the plates. The arms on my truck currently are not terrible but I got a great deal on the other set thats why I haven't really gotten around to it yet.
Bud |
