Old 04-02-2013, 08:52 AM   #1
chevyrestoguy
chevyrestoguy's Avatar
Heater Box gasket kit
I am restoring the heater box for my '64, and a long time ago, I bought a gasket/seal kit that I finally opened last night. What a joke. The foam gaskets are paper-thin compared to stock. Even my original, nearly 50 yr old gaskets are about 3 times as thick as the new ones. I want the foam seals that are the stock thickness. The cowl seal barely sticks out past the lip of the flange. If I installed this kit, my truck would have dozens of air leaks. I want to have a tight seal everywhere, and this kit is not going to cut it. The company that produced my kit was called Repops.
Any suggestions on a good quality (thick) seal kit?
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-02-2013, 10:05 AM   #2
1963c-10
1963c-10's Avatar
Re: Heater Box gasket kit
You might have to get sheet gasket from your local auto parts store. Use the gasket kit as a template and cut your own. An exacto knife or razer blade and I find that using old spent ammo cases make great punches for bolt/screw holes (just make sure the rounds are empty and primers spent).... .25 / 1/4, .38 3/8, .50 1/2" etc....the sheet gasket is made in several different thicknesses.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-02-2013, 10:24 AM   #3
Rich 5150 69
Rich 5150 69's Avatar
At some point I will need the gaskets. I used RTV for a temp patch the last time mine was apart when the core decided to leak and changed it out during the winter.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
