04-02-2013, 10:04 AM | #1 |
I need help with GM part numbers
I have two new GM doors and need to see if they were made as manual or power window doors. At least I thought that they made them different. The numbers are 15571643 and 15571644. Does anyone have that information. Keith? I also have two new GM fenders but don't have any worries about them.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
04-02-2013, 10:20 AM | #2 |
Re: I need help with GM part numbers
The doors are the same. You just use a hole saw to drill for the power window harness. The doors are pre dimpled for drilling.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
04-02-2013, 11:08 AM | #3 |
I figured that there was different access holes for the manual window crank verse the power window. I have not had either one of these doors apart for a long time so I don't remember what they inside looks like between the two.
04-02-2013, 01:38 PM | #4 |
78K & 79C Jimmys
this is the door panel from my 89 burb ,power/power(dirt around square from switch)
now in the 78, the crank comes right out,same spot
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-02-2013, 07:22 PM | #5 |
I am getting off the subject here. So if what you showing is correct then can I take a manual door panel and put in my switches if they are in the same places. I realize that I would have to square out the hole since the manual is round. Does that make since. I am stripping an interior tomorrow that has some nice gray manual door panels and I have power windows and locks. I can just modify the manual panels to make them work since they are in good shape.
04-02-2013, 08:52 PM | #6 | |
78K & 79C Jimmys
this is the drivers,left is power windows(has the big switch hole),right is just power locks
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 04-02-2013 at 08:59 PM. |
