4 link question
i have a 85 short bed c10 that has bags on bars im running a 10" notch but the other day i was looking at it layed out and noticed the rear end pulls forward towards the front of the notch when i lay it out and goes back center when i lift it up im running a triangular 4 link any suggestions on how to get it from pulling like that
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 4 link question
Are the bars parallel to the ground at ride height?
Just the arc of the arms traveling upward will move them slightly forward. The 4-link should keep your pinion angle the same throughout it's supsension cycle.
Re: 4 link question
It should keep the pinion angle but the wheelbase still changes (since it's swing on an arc).
Square
Re: 4 link question
the longer the bars the less noticeable it is.
Squarebody Syndicate |
Re: 4 link question
There are a lot of vairables when installing a triangulated four bar. Length of the bars, angle and hight all change what your pinion angle and wheelbase will do. With normal suspenion travel these changes can be kept to a minimum but when you get extreme (10+ inches) of travel you have to have computer designed parts and **** and aerospace dudes to make it work.
I just finished my own redneck garage, got me a wire feed, ebay directly from china, double throw down stainless steel triangleulated hum dinger of a four (4) link and I can tell you first hand, they don't come with instructions. I'll wrap this up here real quick I promise.. Ok, I found that on my 4 link that I had to raise the front upper bar mounts on the frame and this took a lot of that axle moving forward crap. But not all of it. I finally gave up and put in bump stops to limit the upward travel to where it started moving forward more thatr 3/4 inch or so., Remember, not only does it look lame, youir driveshafy yoke is moving into the transmission (unless you have a 2 piece) I just started with my ride hight very low and buiilt from there. Don't go up a whole lot but so what. Goes down a ton so thats it.. Piece |
