Old 06-19-2003, 08:39 PM   #1
BadCo
Question 61 rear ends
I have recently purchased a 61 Apache shortbox fleetside.I have been reading about the rear end swaps.I have a rusted all to hell 71 c-10.Yes both trucks have the original rear end.I measured the rear end in it and theres no way it will bolt in.I have some hollander books and 61-62 have a different rear end than the rest.I read about the chevy duty rear end kit.Do they have a webpage?Is there a rear end that fits or will I be better off to get a ford 9" and have it made to fit?Has anyone changed there rear end in a 61?
BadCo is offline   Reply With Quote
Old 08-15-2003, 11:30 PM   #2
xextr3m3
I would also like to know, especially since the eaton is not a popular rear
62 c10 short fleet 350/350 dropped
87 toy: SAS 35" MT/R's, 5.29's, detroit rear, exocage
xextr3m3 is offline   Reply With Quote
Old 08-16-2003, 03:55 AM   #3
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Hi BadCo, Xextr3m3, and welcome from Calirfornia
americanclassic.com has a link were you type in you vin, and it gives you a list of what options were from the factory like trannies, engines, rear ends, etc.
ChevyDuty has a website, it's chevyduty.com.
The 1960-62 trucks had torsion suspension, and was change in '63 to coils up front, and the frame rails are spaced differently from the 60-62's.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 08-16-2003, 12:49 PM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
Welcome from Texas.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 08-18-2003, 08:19 PM   #5
phil61swb
I have a 61 short fleet. I have changed the rear end out on mine. However I also changed to a 63 style frame. I cut off the trailing arms and removed the entire rear end assy. I then used the entire leaf spring & rear end assy from an 82 chevy. I am not sure about the difference in widths between the 61 and 63 style frames. At the same time I swapped the whole front cross member from the same 82. In the end I had to slightly modify the leaf spring hangar brackets on the front only and the front cross member matched up 5 out of 7 holes on each side with the other 2 only 1/2 hole off. Results: 5 lug wheels, front disc brakes and power steering. Dont know if this helps, but there are a lot of options.
Phil
61 short fleet
69 C10
97 Astro Van
phil61swb is offline   Reply With Quote
