![]() Join Date: Apr 2011
Rag Joint
Has anyone seen a rag joint with this wire? Is it a ground wire? Came off of a 72 Chevy. This is the only one I have seen.
Re: Rag Joint
Yep, ground.
Re: Rag Joint
Mine has it.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
![]() Join Date: Jun 2012
Re: Rag Joint
mine had it also
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
Re: Rag Joint
Have a 67 chevy all stock, going to drop spindle 2.5" and 4" drop springs in rear. Any prob. with drive shaft? any other issues to prep. for? Thanks for any help!
![]() Join Date: May 2010
Re: Rag Joint
My 69 has one too.
Re: Rag Joint
Might try posting in the forumn instead of someones thread. Get more help that way
Re: Rag Joint
You're right, just figured that out. I'm new online,
Thanks for the reply. |
![]() Join Date: Dec 2012
Re: Rag Joint
Mine has that wire too. I recently replaced the steering box and cleaned things up while I was doing it. I must have missed the wire the first time while putting things back together...... Everything worked as it should including the horn. I saw the wire connector hanging out a bit later and took it apart again and installed it properly. Everything still works and now it's prettier.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
