04-03-2013, 03:24 AM | #1 |
oil filter access with headers ????
I have these headers from summit racing and was wondering if the oil filter access is still going to be ok.It looks pretty tight in there.Has anyone had a problem with this when installing long tube headers????
http://cgi.ebay.com.au/ws/eBayISAPI....m=390568924655 |
04-03-2013, 08:37 AM | #2 |
Re: oil filter access with headers ????
i have long tubes on mine and its tight but i can still access my oil filter.
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
04-03-2013, 08:45 AM | #3 |
Ceramic coated headers require a special break in routine. This routine doesn't match the proper break in of a new engine. Might wanna add these later after engine/cam break in.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-04-2013, 03:12 AM | #4 | |
Parts and more parts
I put my ceramic headers on a long time ago and have had no issue with the break in, since the engine and the headers went in together.
Frank |
04-04-2013, 07:49 AM | #5 | |
If you "properly" broke in your engine, then those temps will cause damage to the header coating, that will break down over time versus properly breaking in the headers thru heat cycles. It clearly states in the header instructions not to use during engine break in and it voids the header warranty. http://static.summitracing.com/globa...54hkr_scan.pdf Its just advice.....take it or leave it
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 04-04-2013 at 07:59 AM. |
04-04-2013, 07:56 AM | #6 | |
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
04-04-2013, 02:55 PM | #7 | |
Frank |
04-03-2013, 12:35 PM | #8 |
i can get to mine just fine, i have hedmanns
"DON'T TOUCH THE TRIM!!"-Early Kyler |
04-03-2013, 11:21 PM | #9 |
I have ran headers in many different vehicles/styles/and configs , never have had filter access issues.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
