Old 04-03-2013, 09:22 AM   #1
WDE86
Turn signal fuse keeps blowing, e-brake light won't go off.
In my '86 pickup, I keep blowing the 15A fuse for the signal lights. Also, I've noticed my e-brake warning light in the dash continuously burns. I'm suspecting either a short or some fouled wiring somewhere but I'm not sure how to check for those problems. Anyone have any advice? Are these two problems related?
WDE86 is offline   Reply With Quote
Old 04-03-2013, 10:38 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Turn signal fuse keeps blowing, e-brake light won't go off.
Check buld sizes. An incorrect size will burn up fuses. Check for burned bulb. A bad socket will also burn fuses.
For the e-light, adjust the pedal switch.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-03-2013, 10:41 AM   #3
WDE86
I hate to be needy, but I have no idea what that is or where it's at. This is my first rodeo when it comes to tending to an older vehicle.
Old 04-03-2013, 12:32 PM   #4
gchemist
gchemist's Avatar
Follow the emergency pedal up the kickpanel. At the top of the pedal there is a switch. The switch activates the instrument bezel e-light. Better yet, pull the e-brake release handle. Your pedal may not be all the way "up". If it is, then the switch is out of adjustment.
Old 04-03-2013, 12:34 PM   #5
WDE86
Thanks. I'm sure that was a stupid question, but I don't think anyone is born knowing this stuff. Thanks for the help. You rock.
