04-03-2013, 01:38 PM | #1 |
70 k5 body with 72 k5 frame problem
i finally found me a k5 and started the resto. the k5 is a 1970 chevy cst 4x4. when i bought the blazer the front end was smashed and frame was bent. so i bought a 1972 4x4 frame and converted it to 2wd. now that im mocking up the body to frame i noticing some diferences. the major one is the body will not sit because of the rear frame and brace of body, my 70 frame looked cut in the rear and this 72 had horns to mount the bumper, were the 72 body and 70 body different or frame?
04-03-2013, 06:16 PM | #2 |
Just a nother gear head
Re: 70 k5 body with 72 k5 frame problem
the answer is, both. the frame changed in 71. so the body had to change also. just the rear sill/cross brace is different. 71-72 body has notches to clear the extended frame rails. you can either cut the frame back and run a bumper and brackets for a 67-70 or make the notches in the sill.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
04-03-2013, 10:11 PM | #3 |
Or we could've traded frames before you turned yours into a 2wd. I have a 70 frame with a 71 body
I will have a 71 frame available as soon as my tub is painted and swapped over. Hey do you have that blue front end for sale on CL
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
04-03-2013, 11:57 PM | #4 |
the blue front end is my buddys, i have the roof for sale.
04-05-2013, 05:26 AM | #5 |
Cut the horns off to the same dimension on your original 69-72 frame as fxdxharley indicated. Sport bumpers are the same for 69-72, if that is what you are going to use. Brackets will be necessary if you don't have them on your old frame. I don't see the rear most cross member in the pics of the 72 frame. If it is not there, use the one from your old frame as it ends up real close to where you cut the frame horns and should be there for strength.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
04-30-2013, 01:07 AM | #6 |
Fxdxharley is it possible that this change was a mid-year '71 change? I have a '71 and it does not have the extended rails nor the notches in the rear sill.
Thanks. Jeff Posted via Mobile Device |
04-30-2013, 02:27 PM | #7 |
Junior Member
I had the same problem when I put a 71 body on a 72 frame. I just made a template of the notch from the 72, traced it on to the 71 body, and cut it out. It is hardly noticeable.
04-30-2013, 03:43 PM | #8 |
Blazertime, I am pretty sure that all of the 71's had the same frame as the 69 and 70 with only the 72 being different (having the horns). My 71 is like yours no horns or notches while my 72 has them.
70 Chevelle SS (clone), 454, 350 auto 71 K5 350, 350 auto, 3" body lift, 35's -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |____|__|___] *.*..*.*.._@_ _ _ _ @ |
04-30-2013, 05:21 PM | #9 |
Excellent, thanks Lopemaxx. I just bought this thing a few months ago out of California. Had someone else look at it for me and am just now having time to get into it and see what I got. I am seeing a few odd things and just trying to chase them down.
Thanks again for the info. Jeff Posted via Mobile Device |
