Old 04-03-2013, 02:34 PM   #1
tinydb84
tinydb84's Avatar
Transmission Question
(I tried searching but couldnt find a clear answer)
I bought a 2004 5.3 without a trans. I want to go with a 4l80e. Do I have to get a specific year for it to work? Or can I just tell the company that is modifying the harness what year trans I have and that be enough?
I know different generations of the trans have pro/con's but for a mildly modified 5.3 I dont think that would matter, correct?
Thank you!
David
Instagram: myfabguy
Old 04-03-2013, 02:48 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Transmission Question
they had changes in I believe 96 or 97, though either generation can technically work. I'm running a 97 4l80e. I believe top bolt on early transmissions may not line up (tho its fine to install without that bolt)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-03-2013, 03:15 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
Ditto. I'm running a 97 4L80E behind my 07 LQ4.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-03-2013, 04:29 PM   #4
tinydb84
tinydb84's Avatar
Great. Thanks guys!
David
Instagram: myfabguy
Old 04-03-2013, 06:20 PM   #5
bohmankid
bohmankid's Avatar
But O.P. has a 5.3, won't he have to have his PCM tuned to accept the 4l80 since 5.3's didn't come with that trans. How does that work?
bohmankid is offline   Reply With Quote
Old 04-03-2013, 07:26 PM   #6
clinebarger
Yes, Transmission calibration segment swap using EFIlive or HPtuners.
tinydb84, A mild 5.3L doesn't require a 4L80E...All Im going to say, Me, Brewcity & Wasted Income have already been in a debate over this.
clinebarger is offline   Reply With Quote
Old 04-03-2013, 07:35 PM   #7
tinydb84
tinydb84's Avatar
I burned up 2 700r4/4l60's in a almost stock Camaro....is there a thread with the debate? I would like to read it if possible
David
Instagram: myfabguy
Old 04-03-2013, 10:08 PM   #8
clinebarger
'98 & up rollerized 300mm 4L60E's with certain upgrades will hold any N/A 5.3L.
You smoking stock 700R4's is a whole other matter.
Old 04-04-2013, 09:30 AM   #9
Jon01
Jon01's Avatar
Agreed 100%.
I have a friend who ran low 11's n/a on an internally stock 4L60E in an F-body.
That's way more punishment than a 5.3 will dish out.
To put an 80 in it you'll have to do the segment swap(find a good tuner!) and sort out the wiring difference too.
If you want an 80 I'd sell the 5.3 and find a 6 liter/80 dropout complete. Much easier.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 04-04-2013, 09:34 AM   #10
Wasted Income
Boosted Member
My setup requires the use of a 4L80E....because I hate swapping out transmissions.
tinydb84, clinebarger is a smart guy, and from what I gather, he deals with transmissions professionally on a daily basis. He's probably right that a 60E would suit you fine for a mild 5.3.
HOWEVER, I have also seen mild N/A 5.3s shred 4L60Es. Even in bone stock silverados.
If you can find an 80E for a good price, there is no reason not to stab it in your truck...especially if you're starting your LS swap from scratch.
My $0.02
Turbo diesel
Old 04-04-2013, 01:35 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Lol i think cline and I have argued over this in probably 6 different threads. I break stuff so I just built an 80e behind my 6L, but short of running boost is figure u might break the rear end before a good (read, GOOD, 4L60)
smoking a 700r4 is easy, i'd wager it was the first trans most hobbyists destryoy first.
Old 04-04-2013, 01:57 PM   #12
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
My TBSS has a 4L70e in it...the "super duty" version of a 4L60e. It's been rebuilt once (stock) by the dealership and living behind the LS2 in this 2.5 ton brick...when it goes again and I believe it will...I'm hoping I can get someone as sharp as clinebarger to build it for me, as I plan on hp upgrades and really don't want it to ever have to come back out again.
I will say I like the gear ratio's in my 4L85e better then the 4L70e. Its more like the 200-4r and turbo350 the truck had in it, prior to their replacement.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-04-2013, 08:56 PM   #13
clinebarger
Parts list for 60E/65E/70E
Sonnax Smart Shell...http://www.youtube.com/watch?feature...&v=P_T02PDnUbI
Sonnax Smart Input Housing...http://www.sonnax.com/product-lines/...ion/parts/3966
Pin-less Accumulator Pistons...http://www.sonnax.com/product-lines/...ion/parts/3092 Forward Accm...http://www.sonnax.com/product-lines/...ion/parts/3110
Sonnax 2nd piston...http://www.sonnax.com/product-lines/...ion/parts/2012
Sonnax Billet Forward Clutch piston...http://www.sonnax.com/product-lines/...ion/parts/2012
Wide Sungear Bushing...http://www.sonnax.com/product-lines/...ion/parts/3096
Trans-Go SK-4L60E...http://transgoonline.com/products.ph...dcountview=Yes **If you want hard shifts go with the HD-2**
Trans-Go high rpm return springs...http://transgoonline.com/products.ph...dcountview=Yes
Trans-Go Pump Rings...http://transgoonline.com/products.ph...dcountview=Yes
Trans-Go Separator Plate...Year specific
Alto Products Red Eagle & Kolene 3-4 clutch kit...057757BHP, This is really the only weak friction in a 4L60E.
Borg Warner sprags...Input/Forward & Low/Reverse.
New Delco 5 pinion Input & Reaction planets.
New Torrington bearing kit.
Replace ALL other bushings...Hydramatic uses aluminum bushings sporadically.
Old 04-04-2013, 10:45 PM   #14
68GMCCustom
thanks clinebarger! now at least I have the shopping list. the 70e has the 5 pinion f&r doesn't it?
Thanks!
BTW....anything in particular I should do for my 480ft lb rated (I think) 4L85e? I plan on roughly 3k stall torque convertor soon.
Kurt -
Old 04-05-2013, 09:16 AM   #15
Wasted Income
Boosted Member
Great info. I'm sure that will help a lot of guys out.
Turbo diesel
Old 04-05-2013, 07:57 PM   #16
clinebarger
Thanks!
Both the 65E & 70E have 5 pinion planets from the factory.
4L80E's are pretty stout in factory form, A TransGo 4L80E HD2 shift kit would fix what most commonly goes wrong with a 80E....Direct clutch burn up!!
