Brake Issue
I'm looking for some advice on a brake issue I've got on a 72 C20. It's got stock power brakes with Delco Moraine parts.
With the transmission in drive, the brake pedal goes all the way to the floor and there is no braking. When I put it in neutral, I'm able to pump the brakes up to at least get the truck stopped (not normal, but at least partially working). I pulled a wheel last night just to check what the front pad wear was like and they look almost new still, so it shouldn't be a pad issue. I also checked the brake fluid level in the master cylinder and it was good. Does this sound like either a master cylinder or booster issue?
1972 C20 Custom Camper 1972 C10 Under Restoration |
![]() Join Date: Dec 2012
Re: Brake Issue
sounds like master cylinder to me. have you tried bleeding to see if fluid actually comes out of any of the 4 corners?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Re: Brake Issue
I haven't tried that, but up until a couple of days ago they were working fine and where the master cylinder was still full and there were no signs of fluid on the ground, I wasn't thinking it was a fluid related issue.
Are you suggesting removing a hose at the caliper and then pumping the brakes a bit to see what comes out?
#4 | ||
"I ain't nobody, dork."
Re: Brake Issue
Just loosen the bleeder screw at the caliper or the drum and see what comes out.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
![]() Join Date: May 2012
Re: Brake Issue
your old master cylinder may be bypassing fluid internally , first like others said try bleeding the brakes, then go from there. it does sound like m/c...you can adjust the rear brakes to get a better peddle once you get the brakes working properly again...
Re: Brake Issue
Thanks for all the advice. I'll try bleeding first and then, most likely end up replacing the master cylinder. Should I check (bleed) all four wheels or is one enough? If I either get fluid coming out or don't, what is that telling me?
Re: Brake Issue
all four need to be bled.
