Old 04-03-2013, 03:59 PM   #1
Thunderace1997
Which aftermarket tach?
I want to add a tachometer to my 91 suburban. Is there one that I can swap over using junk yard parts? Should I just buy an aftermarket one? I have a 350 with a 4l80e with a compushift 1.
Thunderace1997 is offline   Reply With Quote
Old 04-03-2013, 07:04 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Which aftermarket tach?
I've got an aftermarket tach in now but will be going through my interior this summer and this one has my eye. Might have to try it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-03-2013, 07:33 PM   #3
Thunderace1997
With mine being a 91 I have an electronic speedo...right? Do any of the trucks/blazers come with a gauge cluster that has the tach and could bolt right up to my existing wiring?
Old 04-03-2013, 08:14 PM   #4
68Timber
68Timber's Avatar
Yes, you have what I think is called the VSS speedo, but this replaces the fuel gauge and comes with the tachometer wire. I don't think this affects the speedo function, does it?
John
74 Honda Z50 build
Old 04-03-2013, 08:23 PM   #5
Thunderace1997
I'm sure it wouldn't. It's a little pricey though. If there was another truck or blazer that had a gauge cluster that would fit I could go to the junk yard and get that cluster much cheaper.
Old 04-03-2013, 08:33 PM   #6
68Timber
68Timber's Avatar
Those days are long gone. Although you might get lucky. Tach clusters for these trucks are about the only thing rare about them and you have the most rare combo of all.
John
74 Honda Z50 build
Old 04-03-2013, 09:47 PM   #7
Paul83
Paul83's Avatar
I would like to try and use this too. Where would you get it from?
Paul83 is offline   Reply With Quote
Old 04-05-2013, 08:46 PM   #8
68Timber
68Timber's Avatar
Here tis: http://www.gmsportssalvage.com/?q=node/1530
John
74 Honda Z50 build
Old 04-05-2013, 09:02 PM   #9
Paul83
Paul83's Avatar
Thank you sir. I will be ordering one soon for myself.
Old 04-06-2013, 02:29 AM   #10
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Check out my cluster redo in my sig below
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
