Dutch guy has problems with brake lines
Because US sizes are considered odd in Europe, 1/4" brake lines are not common, usualy everything is 3/16". what is the real problem when using only 3/16" tubing all around?
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
Re: Dutch guy has problems with brake lines
As far as i know there is no problem, I used 3/16 all the way around(4 wheel disc) and have no problems.
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=534956 |
#3 | |
I mean force = pressure x surface space..so the diameter of the tubing should be an issue right? or has it to do with the response time after applying the brake?
Use 3/16 everywhere. Everyone does be it street car, race car or cable car. 3/16 steel brake line is the ticket. :0
Ok, so the diameter of the brake line doesn't matter.
Another question: will the original brake proportion valve work now I have converted the front to disks? I always thought the split was about 60% front 40% rear? is there a difference between all drum brakes (without a booster) and a disk front/drum rear (with a booster) setup?
