Old 04-03-2013, 08:28 PM   #1
rwmiller72
87 tbi no start at times
Truck runs good most of time, when rains or is humid will not start? I think I have an ignition switch problem,anyone have suggestions?
rwmiller72 is offline   Reply With Quote
Old 04-03-2013, 10:23 PM   #2
rs74
rs74's Avatar
Re: 87 tbi no start at times
Cracked distributor cap? Getting moisture inside the cap.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-04-2013, 10:43 AM   #3
Low87
been here longer than Liz
Low87's Avatar
What Roy said. Check the ICM connection on the dizzy. Might not be making enough contact. Open it up, if there's surface rust that's likely your problem. Lightly sand it off (both pieces) then use dielectric grease on the contact area before screing back down.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-04-2013, 10:52 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
my 87 had issues like that
i even replaced the pump
got stuck again,
found a cut/nicked/hard baked area in the power line over the drivers rear wheels arch
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-04-2013, 11:27 AM   #5
Low87
Low87's Avatar
Good point John. Had a starting issue with my K5, couldn't figure it out til we dropped the tank. Some low IQ PO had spliced the trailer plug ground into the fuel pump ground wire. Sometimes the connection was loose enough to cause a problem.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-05-2013, 11:04 AM   #6
Desert1957
Desert1957's Avatar
When you say "Will not start" do you mean will not crank over? Or cranks over and will not start?
Desert
Desert1957 is offline   Reply With Quote
Old 04-05-2013, 07:50 PM   #7
turbo350
I had the exact same issue on my '87 tbi 350. I put a new ignition module and dist cap. Problem was solved.
turbo350 is offline   Reply With Quote
